What are all these wires doing on my mechanical engine - the non-intercooled version
Old Jan 7, 2007 | 12:38 PM
Begle1's Avatar
Originally Posted by smoky beast
which one do you unplug for the timing advance on the non-intercooled?
thanks again
smokin okie
That would be "H", the KSB controller.
Not recommended for long periods of time, however.
Old Jan 7, 2007 | 02:22 PM
GIT-R-DONE's Avatar
What does KSB stand for and what does it do for the motor/pump? Learning something new today, but thats it for today....
Old Jan 7, 2007 | 03:46 PM
Begle1's Avatar
The "KSB" stands for something German (Bosch pump means German terminology).
The KSB advances timing during start-up and cold weather operation in order to warm the engine up faster and run better during start up; disconnecting it raises timing, but does so by increasing pump pressures in a not-so-good-for-long-term way.
At least, that's my understanding...
Old Jan 7, 2007 | 05:03 PM
The Begle's got it.
KaltStartBeschleiniger, or "Cold Starting Aid".
Old Jan 7, 2007 | 05:47 PM
Begle1's Avatar
Leave it to the Germans to use the word "Beschleiniger" for "Aid".
Old Jan 23, 2007 | 09:43 PM
1stGen545's Avatar
run power from key in run position to G that is the only thing you have to have to make it run and the wire to the starter solenoid , put power from a push buton to M & L that control D and all the rest is crap that dodge put on them for people that think that think when you turn the key that the truck should do every thing for you. Pull the spring out from under G and you dont even need power there just put a pull cable on the kill lever on the side of your pump.
Old Dec 25, 2014 | 08:10 PM
SWI Don's Avatar
Pictures are not showing
You couldn't by chance repost the pictures? Or anyone that downloaded them.
Thanks,
Don
Old Dec 26, 2014 | 02:16 AM
Originally Posted by SWI Don
You couldn't by chance repost the pictures? Or anyone the downloaded them.
Thanks,
Don
Of what?
Old Dec 26, 2014 | 07:44 AM
SWI Don's Avatar
A: Grid heater ground
B: Air temp sensor
C: Engine ground
D: Grid heater power
E: Oil pressure sender
F: Water in fuel (WIF) light sensor
G: Shutoff solenoid
H: KSB solenoid
I: Main bulkhead connector
J: Low vacuum warning sensor
K: Starter relay
L & M: Grid heater relays
N: Brain box (runs grid heaters, WIF light, and KSB)
B, E, G are the main ones. Thanks. What switch is wired inline with the KSB? Any info on the connectors would be great.
Thanks
Don
Old Dec 26, 2014 | 08:01 AM
flyboy129's Avatar
Thanks
Don
On my I/c engine, the ksb is wired in with the shutoff solenoid since they both require 12 volts when running. I'm not positive the non-i/c version is the same, but I would think it would be.
Old Dec 27, 2014 | 07:22 PM
1972RedNeck's Avatar
You have something wrong. Non I/C need power when running and the I/C engines don't - they only get power when starting/first started.
Old Dec 27, 2014 | 07:59 PM
flyboy129's Avatar
Yes, that is true, however, the same 12 volt power is applied to both. The I/c versions use a temp sensor (thermistor) in the head acting as a switch to tell the 12 volts when to switch off. Non I/c use kind of a wax heating element to operate the ksb. I should have stated that more clearly. Must have not been awake fully when posting.
1985cucv
Jun 12, 2009 09:50 PM
bigblue70
May 29, 2009 08:39 PM
440727
Oct 30, 2008 07:14 PM
wannadiesel
Mar 31, 2008 10:11 PM
sammy340
Apr 5, 2005 03:55 PM
