Intercooled vs. non-intercooled
Old Oct 26, 2008 | 06:04 PM
440727's Avatar
Hi Guys ! As you can see I'm new to this and need some help and info. I am looking for a 1st Gen because I like the body style and what they are. Anyways ! I have seen a few intercooled trucks and then your non intercooled trucks. Does it matter much the difference I/C vs. NON I/C ? I need the truck to pull around 8k and sometimes more. Not everyday but weekly.
Old Oct 26, 2008 | 06:12 PM
MBolivar's Avatar
An intercooler cools the otherwise heated compressed air, making it denser. This dense air allows for better combustion, hence more horsepower. If you're going to tow, it's a must have. Others have towed with a non I/C set up but EGT's have to be closely watched. If you're going with aggressive fuel settings, an I/C will be of great help.
Old Oct 26, 2008 | 06:14 PM
Richie O's Avatar
366 Spring Chicken
Both have same power levels stock. Both will pull fine a stock levels. I hauled a 7500 pound tractor on a trailer behind my stock 89 and could floor it all day long with no problems. That was with a stock 727 auto as well. Don't expect a hot rod truck at stock levels. They haul fine but are not the fastest things on the road.
Old Oct 26, 2008 | 06:45 PM
MBolivar's Avatar
Richie, I didn't even think about stock levels.
Old Oct 26, 2008 | 07:00 PM
For what you are planning to do with the truck it doesn't much matter which one you get.
When stock, the non-intercooled trucks tend to run stronger.
Old Oct 26, 2008 | 07:05 PM
440727's Avatar
I was going to pull a 18 open car trailer with a 1967 Dodge Coronet on it around here in Ohio. And hopefully down the road maybe do a little playing with the hp and tq numbers.
Not to change the subject but how hard is it to turn a non I/C into a I/C ?
Old Oct 26, 2008 | 07:10 PM
Montana2x2's Avatar
I agree, quite a bit stronger in my experiance.
Old Oct 26, 2008 | 10:04 PM
tcs 91's Avatar
you can get a snow or equal water/meth inj syst. and just use distilled water. that will keep the egts down the cheapest and simplest. use some meth if you need more power [if your trip is going to be hilly this week]. much easier than retrofitting an ic or water/air ic. good 1st upgrade after turning up the pump a little. no matter where you end up with mods, it's still viable. yup.
Old Oct 26, 2008 | 10:20 PM
Non intercooled trucks have less to go bad and better automatics trannies then the intercooled trucks in my mind. Not only that but a stock non intercooled truck will pull like a bear compared to a stock intercooled truck.
They all had the same 5 speed from 89-93 but in 89-91 NON intercooled trucks had the 727 3 speed automatic with 3.07 gear ratios which is a bulletproof setup.
intercooled trucks had a the A518 with o/d which is nice but the tranny gets hot and causes a loss of power when towing due to the stock crappy torque converter.
Id recommend getting a 2WD Dually NON intercooled first gen with the 727 auto or a 5 speed. Make a good tow rig and could be fun in the future when you start the mods. HOpe this helps... Brandon
Old Oct 26, 2008 | 10:26 PM
So where you located?
Old Oct 26, 2008 | 10:30 PM
BearKiller's Avatar
I would rather have a non-IC engine and then add the inter-cooler.
The non-IC just seem to be better all around, quicker to start and more powerful.
Old Oct 27, 2008 | 10:27 AM
Richie O's Avatar
366 Spring Chicken
Just get one of each. Thats what I did.
Old Oct 27, 2008 | 01:38 PM
peobryant's Avatar
What do you mean quicker to start?
Old Oct 27, 2008 | 06:46 PM
440727's Avatar
I'm located in central Ohio
Old Oct 27, 2008 | 06:50 PM
440727's Avatar
I need a 4x4 because I do a little off road work with my dad getting logs for lumber once and a while and then hauling the wood from the mill to his place.
I want a 5spd. but I know they are really really hard to find !
