turbo questions
turbo questions
hey is there sush a thing as a baffle in the teurbo that a person can take out to alow it to wind up and get a better blow off sound if it is true let me know how hard it is to take out and if eney one hase done it and if theres eney problems in doing it let me know thanks staken
If you can buy it cheaper than a H1C upgrade, then it's a little bit of a mod. HX35's have a 56mm compressor and ours have a 54mm. I would use your exhaust housing and the rest of the HX. I wouldn't use the exhaust housing cause it's a 12cm and it'll run hotter than what you have now on the top end. It would be good to keep though for if you wver wish for twins, you'll need the gated housing.
Under $300, the 12 is going to get hot towing. You cannot use the GDS on the HX but HTT makes a compressor upgrade for it. If you're planning on buying an upgrade and paying nearly 300 for an HX, you could easily find a used S300 62/65/14 for around 800, there were some new ones floating around for 800. But the place removed their prices and I'm not sure how much they are now..
Clucker
22
09-24-2009 09:34 PM
pistazie
ABDTR #5
04-30-2009 08:16 AM
GR40RCapri
10-30-2007 09:37 AM
gman07
04-15-2006 08:32 PM
