Transmission cooler problems
Old Jun 27, 2006 | 01:19 PM
gman07's Avatar
In the process of taking my running boards off, I discovered that the transmission cooler under the bed was just resting on a piece; the bolts were not holding it. However, the dealer doesn't think there was an under-bed transmission cooler offered and therefore can't find the bolts to hold it up. It looks like there was some rubber piece instead of a nut. Does anyone know where to find the bolts to mount it? I'm pretty sure the cooler is shot anyway (it's full of dirt and the fan turns too hard), but I need to have it held up anyway. Thanks for any help.
Edit: The other point of this thread was to announce that I am now a member of the shutoff cable crew. I found that bicycle brake cable works great!
Old Jun 27, 2006 | 05:19 PM
gman07's Avatar
Bump...
The under-bed transmission cooler is a factory option, right?
Old Jun 27, 2006 | 05:21 PM
flashgordon's Avatar
Originally Posted by gman07
Bump...
I have heard menny guys talk about them and thats what i got out of it
Old Jun 27, 2006 | 05:38 PM
Supernova's Avatar
The owners manual on mine states it was an option which by the way increases towing capacity another 2000lbs.
Old Jun 27, 2006 | 05:51 PM
Bump...
Ka it was a slow day so i went and up and got the parts man to look up this option......there was not a cooler option availabe for our truck!!! now hang on just a minute!
This was a dealer installed extra cooler part number 82400846 this number was up dated to ## 82400994 that is NS1...a...probly a long time a go!!!!!!
Heres the good news...sort of
Had him do a parts search and found 1! in the U.S.A. Its at P-K Smiths Motor ink winnfield LA........phone #318-628-4631
Be..a..BE..a... Thats all folks
Dont think that thay will sell you just the atachment parts but maybe thay can open up the kit and tell you what the atachment part parts are or look llike.
Old Jun 27, 2006 | 06:11 PM
gman07's Avatar
Thanks for the help guys. The transmission has lived for a while without the cooler so all I really need is a mounting kit. I may have to get creative if there's only one in the U.S. right now...
Old Jun 28, 2006 | 12:01 AM
theres only one period!!! "NOS" New Old Stock
thats the last new one made.
Good luck with you fabbing
Old Jun 28, 2006 | 04:58 AM
Jim Lane's Avatar
Is this the auxiliary transmission cooler you are talking about?
If it is it has a sheetmetel bracket at both ends and the bolts I think are 1/4" self-tapping sheetmetel screws. It has been awhile since I have had it down so they might have a weld nut in there.
You could use a well nut if you want it insulated from the frame.
Someone ran over a bottle of polish at the body shop, I need to wash the bottom of my truck yet.
I disconnected the thermal switch and have it connected to a toggle in the cab.
[IMG][/IMG]
What's that, my spring bushing is rubbing?
I am getting my springs rearched in about a month or so. Just got to take them off.
[IMG][/IMG]
[IMG][/IMG]
Hope this helps
Later.
Jim
Old Jun 28, 2006 | 07:52 AM
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Hope this helps
Later.
Jim
THANKS i have allwas wanted to see what thay looked like.
Old Jun 28, 2006 | 11:46 AM
gman07's Avatar
Yep, thats the one. Mine was packed full of gravel dust and rocks, but I got it cleaned out and tested the fan. Everything works, now I just have to get it bolted back up. Then it's on to the next problem... (steering problems)
Old Jun 28, 2006 | 12:27 PM
Boatnik's Avatar
Steering Problems? Been there, done that.
Tank_66
Jan 11, 2012 10:12 AM
DJ Turbo.
Oct 13, 2011 09:11 PM
APD
Mar 12, 2005 10:18 PM
Crimedog
Feb 1, 2004 05:31 PM
lezmark7
Mar 29, 2003 09:47 AM
