Aux. Transmission Cooler
Old Feb 1, 2004 | 05:11 PM
Crimedog's Avatar
I use my truck for plowing, and I can't find an auxilary tranny cooler. When in 4-hi if I really push it, I can see temps approach 240-245. In 4-lo, I see temps stay consistantly at 180-190. I can't find find a tranny cooler for 1/2 inch line. Anybody know where to get one? BTW, the tranny temp is inthe hot line. At what temp does the fluid start to break down? Thanks
Old Feb 1, 2004 | 05:31 PM
infidel's Avatar
I've used these before with an electric radiator fan from the junkyard. Heavy duty unit-
http://www.grainger.com/Grainger/pro...626062&ccitem=
When conventional petroleum fluid temperatures exceed 200°F they break down causing seals to crack and leaks to occur. Approximately every 20 degree increase in temperature over the normal 175°F will reduce a transmission fluid's life expectancy by 50 percent.
ClassA4x4
Jan 21, 2011 06:44 AM
goodtyms
May 16, 2006 08:48 PM
fishin fever
Mar 8, 2006 04:13 AM
Shrimper
Jun 17, 2005 07:00 PM
bigredbrick
Sep 24, 2003 11:46 PM
