steering idea?
Old Jul 19, 2012 | 07:53 PM
DEFlush's Avatar
steering idea?
Ive been tossing this idea around a lil bit and would like some opinions on how you think it would work. my stock drag link is worn and my steering is jacked up from the lift so i figured this could corret my problems without goin to full blown crossover?
Old Jul 19, 2012 | 08:19 PM
enafzige's Avatar
Looks good, if you have appropriate joints on each end that won't bind.
Obviously, the further toward the passenger tire that you put the attachement point, the better benefit you'll receive.
Eric...
Old Jul 19, 2012 | 08:29 PM
DEFlush's Avatar
my plan is a hd tie rod end on pitman side, and a good heim joint on tie rod side . im goin to put the bracket as close to the pass side as clearances allow
Old Jul 21, 2012 | 07:02 PM
DEFlush's Avatar
has anybody ever done a steering setup like this?
Old Jul 21, 2012 | 08:26 PM
simplysmn's Avatar
Crossover would be easier
Old Jul 21, 2012 | 09:03 PM
DEFlush's Avatar
the problem i have with xover is i dont think i have the clearance on the springs and crossmember( i built myspring with f150 rear springs so its a taller pack ),it just dosnt look like i have the room. and my buddy has good steel and a badass tig welder for the bracketry all i need is the joints and to figure out how to get the pitman toclear
Old Jul 21, 2012 | 11:17 PM
simplysmn's Avatar
How Much lift do you have ?you can get away with 4 in Pictures of truck would help also if possible
Old Jul 22, 2012 | 01:00 AM
DEFlush's Avatar
i have about 4-5 inches but its a very tall leaf pack with very little arch
Old Jul 22, 2012 | 01:13 AM
DEFlush's Avatar
im not sure why but i cant figger out how to put my pics up on this thread but i have 3 pics on page 2 of the before and after thread
Old Jul 22, 2012 | 08:18 AM
simplysmn's Avatar
You have Plenty of room to go crossover
Old Jul 22, 2012 | 11:27 AM
BILTIT's Avatar
See this thread from the sticky for crossover, it shouldnt be a problem with your setup.
https://www.dieseltruckresource.com/...t-t291427.html
torq_crowe
Sep 12, 2008 06:59 PM
wap
Sep 11, 2006 12:44 PM
jrussell
Jun 14, 2006 11:04 PM
Begle1
Jul 13, 2005 04:13 PM
Begle1
Jan 26, 2004 03:03 PM
