oil pressure q
Old Mar 29, 2009 | 07:52 PM
flippy1974's Avatar
oil pressure q
i have been around a few of these 5.9 abd they all seem to do the same thing . after sitting for a day or 2 on start up the oil pressure takes a few sec to come up what can i do to make stay primed up so it wont take that sec or 2 to come up .
Old Mar 29, 2009 | 08:31 PM
RSWORDS's Avatar
Well Any engine will take a moment to get oil pressure. Add to that our stock gauges are pretty slow to react and it looks REAL slow.
Old Mar 29, 2009 | 10:56 PM
bigbaddiesel416's Avatar
From: anderson commiefornia oh ya you can keep the "change"
true i am lookin for the link for you i found this device the other day that is an electric h/p oil pump when you turn the key the light comes on so dose the pump takes oil from the bottom pumps it up top (takes 6 sec) and your all (pre lubed) but i think it was like $650.00 so unless your REALY worried bout it i wouldn't do anything!!
Brice
Old Mar 30, 2009 | 02:14 AM
flippy1974's Avatar
well i have the elec and a true wet mech gauge and they both take the same time to come up . my car has pressure instantlly no delay .
Old Mar 30, 2009 | 02:16 AM
flippy1974's Avatar
Brice
yea your right thats alot of money i have thought about putting in a kill switch so i could kill it and be able to crank it till the oil pressure comes up . i just didnt know if there was something eles .
Old Mar 30, 2009 | 08:19 AM
RollinCoalSmoke's Avatar
If your going to rig a kill switch just put a pull cable on your pump. Leave the pull cable pulled out and turn the engine over till pressure builds. But your next problem will be replacing the starter more often. Good luck in your quest for oil pressure before starting.
Old Mar 30, 2009 | 08:24 AM
The_Head's Avatar
I was going to say the same thing, but for trucks that still had the shutoff solenoid.
You could install a switch to keep it turned off, crank the truck for 5 seconds, turn switch on, then start the truck.
Old Mar 30, 2009 | 04:00 PM
flippy1974's Avatar
yea that what i was thinking about just using a toggel switch ,turn it off and crank it then flip it on and start the truck .
Old Mar 30, 2009 | 05:33 PM
GasganoFJ60's Avatar
If you're using good oil there should be plenty of residue all along the inside to keep things lubed for the first revolutions of a startup. The oil pump is gear driven so as soon as the motor turns over it has oil pumping through itself.
Plus, think of all the Cummins' that have gone over a million miles. I dont think all the years of "dry-starting" has hindered them at all.
Also, those pre-oilers that cost an arm and a leg are really intended for vehicles that sit for long periods of time like lets say and RV or a seasonal tractor.
Power Ram 250 C
Feb 20, 2007 11:08 AM
streetsmoker
Feb 22, 2006 06:47 PM
bigragu
Jan 24, 2006 11:16 AM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
