Oil pressure ?
Old Mar 30, 2010 | 12:42 PM
KD93's Avatar
Question Oil pressure ?
Folks, does anyone have numbers on what their oil pressures are cold/hot, and at idle/mid-throttle/WOT? I have 155k on my engine and I got a master gauge from my teacher at school to see what I'm making. My pressure gauge is reading a little funny and I want to figure whether it's the gauge or the sending unit. But I need numbers to see if what I get is about where it should be.
Thanks in advance,
Keran
Old Mar 30, 2010 | 12:43 PM
GasganoFJ60's Avatar
Warm at idle should be about 22psi or so.
Old Mar 30, 2010 | 02:14 PM
Jim Lane's Avatar
The oil sender on these engines are a common part to fail and are easy to replace.
https://www.dieseltruckresource.com/...d.php?t=107789
Jim
Old Mar 30, 2010 | 04:41 PM
From the Cummins manual: 10 psi idle minimum, 30psi rated minimum, 70 psi rated maximum. Rated = max governed RPM under load. All these are speced hot, most of these engines will peg a 100 PSI gauge cold.
Old Mar 30, 2010 | 05:20 PM
KD93's Avatar
Thank you Wanna and Mr. Lane!!! I'm kind of thinking it's the sending unit, but it's always good to know exactly where I'm at.
Old Apr 3, 2010 | 05:38 PM
KD93's Avatar
Just an update on this. I finally found the time to hook the master gauge up, (I put the NPT fitting at the top of the filter pad.) I was wondering if I would get a different reading at the sender unit, so if I have the time tomorrow I'll try that. Theoretically I won't, but I assume nothing!
So, cold I got 55 psi at idle, 75 psi at around 2k rpm, (I don't have a tach.) I took it for a quick spin while not at operating temp, and got 50 psi under a light load 'til I hit the highway. At WOT I got 70 psi. Took her home and idled at 45 psi, just under normal operating temp.
I am very happy, as this gives me a good indication of bearing wear, (or lack of it in my case!) Still, my sending unit is bad, but I'm going to get a real pressure gauge at some stage anyway, so as long as I keep an eye on my oil level I think I'll be ok.
Thanks again for the help folks!
Keran
Old Apr 3, 2010 | 06:11 PM
dieselcrazyw350's Avatar
my truck has 300,000 and cold driving it pegs my 100psi gauge. warm driving around 60 and warm idle is 40
Old Apr 3, 2010 | 07:01 PM
KD93's Avatar
Nice!
Power Ram 250 C
Feb 20, 2007 11:08 AM
streetsmoker
Feb 22, 2006 06:47 PM
bigragu
Jan 24, 2006 11:16 AM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
