OD Questions
Old Jun 22, 2011 | 10:55 PM
soggy's Avatar
OD Questions
If I have my OD controlled by a switch, would a bad temp sensor or the VSS prevent OD from engaging?
A while ago I put a Mag DD trans pan on, since then it refuses to shift into OD. I checked the power and ground to the switch, both are good but still no overdrive. Any ideas?
Old Jun 23, 2011 | 06:50 AM
If it is a switch straight to the OD solenoid, you should have total control and be able engage OD any time the trans is in 3rd.
Old Jun 23, 2011 | 12:12 PM
bigjohn92's Avatar
it could be your overdrive solenoid in the trans . u have to pull the valve body out to replace the solenoid. hope this help.
Old Jun 23, 2011 | 08:09 PM
soggy's Avatar
Thanks, that's what I was afraid of, guess I will have to drop that pan again.
Old Jun 24, 2011 | 08:12 AM
zack_76401's Avatar
From: Lingleville TX but active duty Air Force all over the world currently
Can anyone tell us how to wire up a switch like this?
Old Jun 24, 2011 | 09:40 AM
Splice into the wire at the OD plug that isn't blue, run that wire through a switch to ground.
The blue wire supplies power any time the key is on, grounding the other wire when the trans is in 3rd will engage OD.
Old Jul 1, 2011 | 10:22 PM
soggy's Avatar
It turned out to be OD solenoid, some of the insulation on the power wire was missing and it was shorting against the valvebody.
Old Jul 2, 2011 | 10:18 AM
Shiny's Avatar
This seems easy. I am gonna go try it as a previous owner cut and spliced wires and made a mess of it. So I will just run switched power to the blue wire and run a switch on the other wire to ground. Hopefully thats all that is wrong with it
Thanks!
-Shiny
Turbocrazy
Feb 25, 2013 04:40 PM
popeye4wheeler
Jan 30, 2011 06:24 PM
Clucker
22
Sep 24, 2009 09:34 PM
GR40RCapri
Oct 30, 2007 09:37 AM
gman07
Apr 15, 2006 08:32 PM
