need part number- front sway bar parts.
Old Sep 30, 2011 | 11:10 AM
crossy's Avatar
One of the metal brackets that wraps around the sway bar and ties to the control arm is broken on my 92. Only the I/C 1st gens used the front sway bar , but all i can find listed is the bushing that goes inside the bracket. One MOST brands of trucks/cars and they call these and 'end lenk kit'. anyone havea part number from ANY manufacturer on these. thanx. crossy
Old Sep 30, 2011 | 03:39 PM
Fibrestar's Avatar
I just did mine and still have the packages. The insulators are 03879212 and the links are 04036005. This for a 4wd model. They are all that cheap.. like 18.00 a pc I think!!
The bushings and straps for the frame are NLA and I had to get some from Energy but when I took my bushings off my bar the bar was so thin I had to down size the bushing. So if you need them you have to do it aftermarket. I plan on crossover steer so I won't have my sway bar on for very long!!
Old Sep 30, 2011 | 03:48 PM
crossy's Avatar
Tie rods also
while i'm begging- lol
I'm also having trouble finding the stock LONG style inner tie rod ends. everything I'm finding is much shorter in the threaded area and would require a MUCH longer sleeve in the middle to make up the difference. I only need the one inner so i dont want to change everything. thanx , crossy
Old Sep 30, 2011 | 03:51 PM
BILTIT's Avatar
Here is some info on TRE's that may help.
http://www.partsmike.com/tech-help/tr-dl-id/
Old Sep 30, 2011 | 03:57 PM
Fibrestar's Avatar
I went to Napa and got their USA made models and they were a perfect fit!! oh and lifetime warranty!!
Old Nov 12, 2011 | 08:09 PM
crossy's Avatar
got the numbers of those by chance?
Old Nov 13, 2011 | 12:22 AM
Yeah I need to install my front sway bar as well...2wd if that makes a difference?
Old Dec 13, 2011 | 10:22 AM
crossy's Avatar
sway bar
Fibrestar was that the number for the sway bar END LINKS that are on the very end of the sway bar?? not the ones that hold it down. I couldn't find any listing with NAPA.
I need these things bad now. Just got the whole front suspension/steering rebuilt.
Old Dec 13, 2011 | 10:54 AM
Its the metal piece that is rotted off and is supposed to go up and wrap around the rubber insulator that is on the sway bar.
Old Dec 13, 2011 | 12:34 PM
crossy's Avatar
Dad found it! The part numbers the other guys gave is for the retainer washers and insulators, but we need the actual metal part. Well I found it and unfortunately they are at the obsolete warehouses already and the ONLY place i could find they want $150 for it. they can mail it out today though. NOT
I'm going to plan 'N'(nixon) first then to plan F(fabricate). thanx for the help though team. Crossy
Old Dec 13, 2011 | 01:18 PM
jimbo486's Avatar
Crossy, where did you find the bushings that wrap around the bar inside those brackets?? I'd like to replace mine as well. I'm sure they could stand it.
suprajake
Jun 3, 2013 12:12 PM
tcr
Dec 4, 2007 12:15 PM
Dinner
May 29, 2007 02:02 PM
Robert373
Apr 3, 2007 12:20 PM
