Sway bar/Stabilizer bar size questions/What kit??
Old Dec 2, 2007 | 11:31 PM
tcr's Avatar
tcr
Ok, I've searched and searched and I can't find what size my front sway bar is, and I don't have calipers handy. Does anyone know the size, and is there a bushing kit for both the frame mounts and the rod ends? I would really like to get the greasable type, like the Energy Susp kits, I just don't know the sizes. Has anyone replaced these parts on a third gen. yet? THANKS!
Old Dec 3, 2007 | 03:10 AM
TexasCTD's Avatar
I bet Mike with Lazarsmith could help some with those questions.
http://www.lazarsmith.com/SSSSS.html
http://www.lazarsmith.com/contactus.html
Old Dec 3, 2007 | 05:02 PM
Tiara3100's Avatar
Just replaced my swaybar bushings, installed new Moog 33-34mm bushings. I also installed new Moog sway bar links, only problem is when you install driver side link, grease fitting hit's coil spring perch. I plugged the grease fitting on that side, and drilled/tapped a new grease fitting on the other side.
Old Dec 4, 2007 | 08:28 AM
tcr's Avatar
tcr
Where did you buy and how much if you don't mind?
Old Dec 4, 2007 | 12:15 PM
Tiara3100's Avatar
Dont remember exactly, but I believe the bushings where $12-16 each and the sway bar links were $45 each. I know the bushings from Moog were half the price the dealer wanted. I ordered them from the local parts store.
Fisherguy
Mar 30, 2009 08:52 AM
12 flapper
Jan 13, 2008 09:13 PM
Tiara3100
Nov 13, 2007 11:20 AM
rjm022
0
Jul 21, 2007 09:17 PM
RAM3500 C&C
Dec 7, 2006 04:15 PM
