Steering (box) stabilizer with KORE sway bar spacers?
Old Mar 29, 2009 | 08:51 PM
Fisherguy's Avatar
I did my leveling kit yesterday and put some KORE sway bar spacers under my sway bar, am I going to be able to get a steering stabilizer on there as well?
I know Lazarsmith makes a stabilizer with spacers as part of its design but I was hoping to keep the KORE spacers.
Seems to me it would work if the tab that goes to the pitman arm was welded to the top side of the 2" square tube instead of the bottom side..?
Old Mar 29, 2009 | 09:06 PM
CD in NM's Avatar
I have the Defiant Steering Stabalizer and it works fine with the KORE blocks. If yours is the Lazarsmith stabalizer and it already has a block, then I'm guessing that you will not need the KORE blocks.
CD
Old Mar 29, 2009 | 09:15 PM
Fisherguy's Avatar
I spose as long as the KORE blocks can fit ontop of the stabilizer (between the frame and the stabilizer) it'll be okay.
I was leaning towards the DSS stabilizer, (its made in Canada eh!)
Old Mar 29, 2009 | 10:31 PM
J.Suplanski's Avatar
Thumbs up Dss
Can't go wrong with a DSS, sure took care of my problems!
Old Mar 30, 2009 | 08:52 AM
lniemeyer2's Avatar
Here's my Defiant Steering Stabilizer with Kore drop blocks. Works Great!! Paul will even send you the longer bolts you need to install it.
tcr
Dec 4, 2007 12:15 PM
RAM3500 C&C
Dec 7, 2006 04:15 PM
rockwithjason
Sep 17, 2006 07:41 PM
Inferno Ram
Jun 11, 2006 10:53 AM
Rambunctious1
45
Apr 24, 2006 10:31 PM
