Lost Of Power
Old Mar 24, 2009 | 08:28 PM
Midnite Warrior's Avatar
Lost Of Power
I've mentioned this in another post and nobody had any suggestions. I'm noticing that when I have the BD turned all the way up at a certain point I feel the truck get sluggish. This usually happens by the time I grab fourth gear while I'm hammering it. Or if I'm rollin' down the highway and hammer it by the time its hittin' around 100 MPH it seems like its kind of running out of fuel. From then on its sluggish. If I stop and turn the truck off for at least 5min. it will line back out until I do it again. It only does it when the BD is turned all the way up. Any suggestions?
Old Mar 24, 2009 | 08:41 PM
Riflemanusmc's Avatar
Registered user
Sounds to me like your draining the fuel rail..
Old Mar 24, 2009 | 08:58 PM
dslpwr81's Avatar
X2. I think you answered your own question. When I had my BD, I could drain the rail as well.
Old Mar 25, 2009 | 09:43 AM
kantdrive55's Avatar
DTR Advertiser
Sounds like you are a candidate first for a better lift pump. That isn't going to entirely solve your problem, but it is going to go a long way towards fixing it. You are looking for a gearator style pump that is going to push a fair amount of fuel to keep up with that programmer.
Old Mar 25, 2009 | 11:25 AM
leonesm's Avatar
I agree. My stock pump couldn't keep up with the Bully Dog and I had the same problem. You need an upgraded lift pump to run it on that high of settings. It would be a good idea anyways...
Old Mar 25, 2009 | 01:10 PM
Ok, I'm still kind of learning about diesels. Also, I really didn't have this problem until I changed the turbo. so actually I wasn't quiet for sure if that was the problem or not. Any suggestions on a good brand of lift pump?
Old Mar 25, 2009 | 01:13 PM
Kantdrive55, you said this won't entirely solve my prob. What will solve the problem entirely?
Old Mar 25, 2009 | 02:11 PM
DTR Advertiser
You will get to a certain point in horsepower where no matter how much fuel you put to the CP3 pump it only has the ability to put x amount of fuel to the injectors. Then you are looking at going to an upgraded CP3 or a twin CP3 kit.
If you can ever get your truck hooked up to a good scanner that will show your rail pressure you can get a pretty good idea on where you are fuel wise. It will show you your desired psi versus the actual psi. If there is more than about 4000psi difference under hard acceleration time for more fuel.
Old Mar 25, 2009 | 02:23 PM
DTR Advertiser
I happen to know a company that sells one that is 165gph idles at 16psi. It is a gearator style so they are very reliable. That company might even have a good deal for forum members.... PM me for pricing...
Old Mar 28, 2009 | 04:23 PM
When you replace the lift pump with a BD, FASS, etc.; do you have to remove the stock one out of the tank?
Old Mar 30, 2009 | 09:16 AM
DTR Advertiser
Yes you will have to modify what is in the tank. Our kit includes the in tank modification. We still use the stock pickup tube, we just take the factory pump out and put in a replacement pickup tube. Not too big a job.
j
Feb 22, 2004 10:59 PM
w4xtc
Feb 18, 2004 08:55 PM
popeye
Feb 4, 2004 08:57 AM
JONBOY56
Nov 29, 2003 03:17 PM
claing
Jun 21, 2003 03:02 PM
