Anti Sway Bar Spacers ?
Old Mar 26, 2006 | 01:12 PM
Rambunctious1's Avatar
OK folks, I've got a leveling kit and 4 new shocks ordered and en route to my house. I remember a thread about leveling kits and it mentioned anti sway bar drop blocks. Are these really all that necessary. I've been looking at the KORE variety through desertracingconcepts.net. Of course it says to call for a price and they're closed today. Just looking at the things makes me guess that they're pricey. With this in mind, I don't wanna spring for 'em if I don't have to. Any input would be great. I've already got a bunch of dough in this project between the above parts, H2 rims, and I haven't even ordered tires. Thanks in advance.
Old Mar 26, 2006 | 01:23 PM
cowboy133's Avatar
I built my own blocks out of 1 1/2 " cold rolled steel. Just use the bushings from the sway bar to mark the holes and the length of the blocks. Drill holes cut to length and put them between the frame and bushing. Worked great. I couldn't see paying Kore for something so simple to build
Old Mar 26, 2006 | 01:47 PM
That's pretty cool. How necessary are the spacers though? This is really what I'd like to know.
Old Mar 26, 2006 | 03:08 PM
nriver's Avatar
not sure on really needing them or not.
but my lorenz ones will be here soon.
there must be others that make em also.
I was wondering how think they were.
carli makes some extended links also.
Old Mar 26, 2006 | 03:12 PM
If you don't mind my asking, how much were your spacers? None of the sites are saying how much the stupid things actually cost. That makes me think they're expensive.
Old Mar 26, 2006 | 08:06 PM
JbD's Avatar
JbD
I was running 5" of lift with no sway bar drop. The sway bar end links were hitting my coils, It just bent the washer on the top a bit under the nut. I just installed the skyjacker drop brackets over the weekend, I wouldn't have, but I plan on adding more lift, so I needed to drop it a bit. If there not hitting, I wouldn't worry about it. On the older trucks, guys were flipping their sway bar upside-down, but I don't know if it works on the newer trucks.
Old Mar 26, 2006 | 08:12 PM
tristan21's Avatar
I would assume that without the brackets your front wheel travel would certainly be limited. I wouldnt worry too much about it if your gonna stay on the street. Rockcrawling or any other four wheeling you might want to buy some.
Old Mar 26, 2006 | 08:26 PM
JbD's Avatar
JbD
How??? Please explain. The stock shocks are going to limit droop before the swaybar.
Old Mar 26, 2006 | 08:37 PM
nriver's Avatar
not sure yet, dont have the bill. But sean has been great about his prices.
Old Mar 26, 2006 | 09:55 PM
torquefan's Avatar
Picture the truck with one front wheel fully drooped, and the other front wheel fully stuffed, at the same time. That's the kind of situation where a swaybar limits your wheel travel.
Old Mar 27, 2006 | 06:13 AM
JbD's Avatar
JbD
I can agree with that, but guys looking for that much articulation either use disconnect's or don't even use the swaybar at all. I just wouldn't think with only a spacer a swaybar drop would make that big of a difference.
Old Mar 27, 2006 | 06:20 AM
2-Stroke's Avatar
its called geometry... some get it, some dont
Old Mar 27, 2006 | 06:28 AM
2-Stroke's Avatar
While I'm on the subject... I know the angle off my steering arm will change... and so will the control arm's angles...
question is, will an alignment be needed after a 2" leveling? Thanks and sorry if I hyjacked at all...
I will be making some sway bar drop brackets for my install!
Old Mar 27, 2006 | 06:42 AM
cquestad's Avatar
Get an alignment...they come wrong from the factory more times than less. Use the upper end of the caster settings...and you will never see death wobble.
Old Mar 27, 2006 | 07:00 AM
2-Stroke's Avatar
I have 41k clocked so far... hard miles too... 100+mph is not out of the norm. - the alignment is dead on from the factory... after I install a 2" leveling kit, I would hate for it to drive funny... b/c now it is so nice!! If I get death wobble I will be so ******.
