need part number- front sway bar parts.
One of the metal brackets that wraps around the sway bar and ties to the control arm is broken on my 92. Only the I/C 1st gens used the front sway bar , but all i can find listed is the bushing that goes inside the bracket. One MOST brands of trucks/cars and they call these and 'end lenk kit'. anyone havea part number from ANY manufacturer on these. thanx. crossy
I just did mine and still have the packages. The insulators are 03879212 and the links are 04036005. This for a 4wd model. They are all that cheap.. like 18.00 a pc I think!!
The bushings and straps for the frame are NLA and I had to get some from Energy but when I took my bushings off my bar the bar was so thin I had to down size the bushing. So if you need them you have to do it aftermarket. I plan on crossover steer so I won't have my sway bar on for very long!! |
Tie rods also
while i'm begging- lol
I'm also having trouble finding the stock LONG style inner tie rod ends. everything I'm finding is much shorter in the threaded area and would require a MUCH longer sleeve in the middle to make up the difference. I only need the one inner so i dont want to change everything. thanx , crossy |
I went to Napa and got their USA made models and they were a perfect fit!! oh and lifetime warranty!!
Originally Posted by Fibrestar
(Post 3026216)
Yeah I need to install my front sway bar as well...2wd if that makes a difference?
sway bar
(Post 3026216)
I need these things bad now. Just got the whole front suspension/steering rebuilt. |
Its the metal piece that is rotted off and is supposed to go up and wrap around the rubber insulator that is on the sway bar.
http://i280.photobucket.com/albums/k...9/c716294e.jpg |
Dad found it! The part numbers the other guys gave is for the retainer washers and insulators, but we need the actual metal part. Well I found it and unfortunately they are at the obsolete warehouses already and the ONLY place i could find they want $150 for it. they can mail it out today though. NOT
I'm going to plan 'N'(nixon) first then to plan F(fabricate). thanx for the help though team. Crossy |
Crossy, where did you find the bushings that wrap around the bar inside those brackets?? I'd like to replace mine as well. I'm sure they could stand it.
