master cylinder
Old Feb 15, 2006 | 09:53 PM
fuel4me's Avatar
master cylinder
the master cylinder for my brothers brakes are shot, is it pretty easy to just put a new one in?
Old Feb 16, 2006 | 11:04 PM
BC847's Avatar
1st Generation Admin
Old Feb 16, 2006 | 11:51 PM
Hemi Cat's Avatar
generally they aren't bad to replace. Make sure you bench bleed the master BEFORE you install it.
Old Feb 17, 2006 | 09:26 AM
lovemysan's Avatar
What does bench bleed mean?
Old Feb 17, 2006 | 10:40 AM
JKM's Avatar
JKM
They are fairly easy to take off and put back on, but good luck with it , my buddy with a 93 has been through 5 (or maybe 6) master cylinders, a couple of them only lasted a matter of days , some for a week , and he drove around most of the spring/summer/fall with a bad one because he got fed up with changing it.
Old Feb 17, 2006 | 08:46 PM
2 fittings and 2 bolts, not hard at all. About an hour including bench bleedeing and bleeding the brakes.
Bench bleed means to stick the master in a vise and bleed all the air out of it before you put it in the truck. Instructions will be included with the new master. You must do this or you will never get all the air out of the system.
Old Feb 18, 2006 | 01:58 AM
BC847's Avatar
Seems I recall they want you to run a fitting and short tube from the "Goesoutta" pipe(s) up and down into the brake fluid reservoir. The end of the tube(s) needs to be submerged in the fluid. Pump the piston (where the brake pedal shaft plugs in) till no bubbles are seem coming from the tubes. You'll feel the piston tighten up in the process.
I think that's how it goes.
Old Feb 18, 2006 | 06:33 PM
DODGE 92's Avatar
jkm
jkm tell your friend master cylinder is not the trouble its the booster i had same prob with mine
Gen414
May 7, 2009 11:08 AM
cgmorgan06
Nov 15, 2007 04:02 PM
Heeler00
Feb 18, 2004 01:52 PM
May 13, 2003 09:44 PM
