Master clutch cylinder
Guest
Posts: n/a
I have changed out the slave cylinder and going to buy the another slave and master cylinder from Peter at SBC, but how int he heck do you change our the master cylinder? I see no bolts to unbolt it from the firewall.<br><br>Ricki
Re:Master clutch cylinder
look under the dash on the top right side of the push rod and the lower left of the push rod you will see studs and nuts on them.<br><br>or you can twist the housing from outside and leave the mount in the truck after you disconnect it form the clutch pedal
Gen414
May 7, 2009 11:08 AM
cgmorgan06
Nov 15, 2007 04:02 PM
WACTD
Jul 25, 2006 11:41 AM
Fishbait
Jun 6, 2006 12:34 PM
