Squeaky clutch pedal = new clutch master cylinder under warranty!
I originally drove my truck off the lot in January of this year, when temperatures are generally in the 20's and 30's. As the weather warmed, I noticed my clutch pedal starting to squeak a bit. I called the dealer and they said "Yeah, we see a lot of that as it gets warmer. Next oil change, remind us and we'll lube it."
This morning was the next oil change, and the paperwork claimed they'd lubed it - yet it squeaked more afterwards than before I dropped it off. I had the service tech come out and try it for himself, which eventually led to three people being under the dash of my truck including the head training tech. He finally called it - "we'll just replace the entire clutch master cylinder".
I wish it had stayed quiet, but kudos to the dealer for taking good care of me and giving me ZERO hassles about what some might consider a minor cosmetic annoyance. Not to me - I've gotten very tired of that squeak and I'm glad they're stepping up to do the right thing.
I wish my dealer would get with the program. My clutch has been squeaking since 2K miles. Every oil change I have them put it on the work order to lube the linkage/clutch rod. The dang thing hangs up when you release it. Glad you got some help.
Mine squeaks and drives the wife nutz! She keeps telling me to take it in. I'll have 'em look at it when they do that recall for the fuel lines or whatever it is..
Tony
Tony
Hmm mine squeaks. I just thought it was normal. Course i rarely ever hear it cause either the windows are down with the radio on or the windows are up with the radio on.
Mine squeeked at 30K miles so I stopped at a dealer in California and he said the slave cylinder was going. It would squeek and the pedal would stick on the way up. It was getting harder and harder to push in the clutch.
They replaced the slave cylinder and then it went bad again at 59K, so I went to the dealer and what do you know, it's not under warranty with the 7/70 warranty, so it ran around $425.00 to get it replaced.
If your clutch squeeks, get them to check that slave cylinder. It's a royal pain to have to keep getting it repaired, but it's even worse when you try to let up on the clutch slowly and then have it engage to quickly and jump.
Lubing won't fix'er.
Blair
Blair
Slave cylinder? They told me it was the MASTER cylinder...
koondawg
11-21-2012 04:35 PM
cgmorgan06
11-15-2007 04:02 PM
Ridiculous
03-15-2006 09:26 AM
Sean Allan
02-21-2006 07:46 PM
rockittboy
02-02-2006 04:58 PM
