Diagnosis..? Clutch Master Cyl or Clutch Slave Cylinder??
Old Jun 1, 2006 | 10:47 AM
Fishbait's Avatar
How does one know/check to see if the Master Clutch Cylinder is bad vs. the Clutch Slave Cylinder?
If I put it in gear at a light and hold the clutch down after 6 to 10 seconds it bleeds out and engages in gear and I have to either take my foot of the pedal and move or kill the motor to take it out of gear. I have to keep it in Neutral at lights until I need to move then quickly put it/out of gear. Other than that it still shifts fine going down the hwy.
Old Jun 1, 2006 | 11:17 AM
JD730's Avatar
1. Sounds like time for new/updated clutch hydraulics.
2. I never hold the clutch in at a light unless I know its going to change very soon. Puts alot of wear and tear on the throwout bearing and main bearing thrust surfaces.
Old Jun 1, 2006 | 11:36 AM
slim51015's Avatar
If the slave cylinder was bad it would leak fluid externaly.
Old Jun 1, 2006 | 12:05 PM
graphitecumnz's Avatar
Time for new hydraulics...
Old Jun 5, 2006 | 01:05 PM
Fishbait's Avatar
I have no leaks from either cylinder, but some others mentioned the slave is the one that does most of the work and wuld be the probable cause of losing pressure by bleeding by...(?).
Any advice on how to replace this without an Uh OH...!!
Old Jun 5, 2006 | 01:40 PM
Dusty Ratcliff's Avatar
doesn't really matter which one is bad, you have to replace both anyway, comes as one big unit already full of fluid & primed, a little costly, but a real easy fix, just a bouple of nuts on the slave cylinder & a couple on the master, & I think two screws on the resevoir (sp?) & then one plug in, it's a little tight down there under the pedals & all, but take your time & it's a straight forward fix, good luck, dusty
Old Jun 5, 2006 | 01:47 PM
Fishbait's Avatar
Thanks Dusty,
I ordered a slave cylinder off the net (ac delco) 2 days ago hoping it would be the one needed, saved 42.00 and had free shipping. If I need the master I guess I will order that as well and save 28.00 vs local difference at parts houses.
Thanks for the reply!!
Old Jun 5, 2006 | 03:42 PM
andrew2910's Avatar
i think you should of went with SBC you get the whole system for 240 no pain ready to install
Old Jun 5, 2006 | 05:01 PM
nps's Avatar
nps
The master usually is the one that goes bad. The slave can't bleed pressure, it either works or leaks. The master will bleed pressure internally but never leak externally.
I've got to get another kit from the dealer tonight - at least mine is still under the 12/12 parts warranty for another 14 days so it'll be free.
Old Jun 6, 2006 | 12:04 AM
Bart Timothy's Avatar
As stated in previuos posts, it is your master cylinder which is bad.
Old Jun 6, 2006 | 12:34 PM
Fishbait's Avatar
Thanks..... I needed to know why it is bad vs slave, not fully aware of their respective mechanics.
dieselboy59
Jul 25, 2010 12:32 AM
Gen414
May 7, 2009 11:08 AM
cgmorgan06
Nov 15, 2007 04:02 PM
GR40RCapri
16
Jan 18, 2007 02:07 PM
Heeler00
Feb 18, 2004 01:52 PM
