injectors?
Old May 13, 2003 | 09:51 PM
matt6973's Avatar
injectors?
I have a 99 that i want more power, just installed stainless 4&quot;<br>exhaust, edge ez, afe air filter, drilled out banjo bolts, and a pusher pump. my question is im lookin at these bosh injectors on ebay 275 horse. And curious if there will be a significant improvement in power, im not lookin for more smoke and im not sure about the setting on the ez right now its on 3. I already now the stock tranny is needing help. any tips would be appreciated.<br>thanks matt
Old May 13, 2003 | 10:30 PM
DarrellB's Avatar
Re:injectors?
The 275's will get you a little more low end power, and improved throttle responce. Nice injectors for the money and you can run them without any fueling or timing boxes if needed. I ran them for 4 years until stepping up to some larger ones last year. 8) They are also easy on the EGT's, and will give you a slight improvement in fuel mileage.<br><br>DB
Old May 13, 2003 | 10:32 PM
phox_mulder's Avatar
Re:injectors?
But if your stock tranny is already needing help, it probably won't be able to handle the 275's and the EZ.
A stock tranny in good condition can usually handle that combination.
phox
KRB
May 20, 2007 06:20 PM
GSP
Dec 11, 2005 12:20 PM
W.F.O.
Nov 3, 2005 10:33 AM
darrenG
Jun 21, 2005 10:24 PM
BIGOKIE
Jul 21, 2004 05:53 PM
