Lost the darn tophat spring
Old May 13, 2009 | 07:12 PM
DNRCustoms's Avatar
Well the 3200 rpm spring install was ging pretty good and then when I went to take the spring out of the tophat it all went bad!! I guess my finger wasn't behind it good enough and it all went for a journey.. found it all but the spring, even with the white sheet under the truck.. So I guess I need to call around and try to find it.. I wonder if a Cummins dealer can get it? I'm sure this happened to more than just myself, this is like the 5th one I've done so far and they all went good besides this one
Old May 13, 2009 | 07:20 PM
TIMMY22's Avatar
Please PM me.
Old May 13, 2009 | 07:30 PM
archer39's Avatar
Cummins probably won't have it. You need a bosch pump shop.
Old May 13, 2009 | 09:14 PM
93John's Avatar
I got mine from my local pump shop. They had it in stock.
Old May 13, 2009 | 09:53 PM
roxxx's Avatar
I have manage to find Pump parts at the AG shops well Case IH anyways
Old May 14, 2009 | 12:36 AM
Alwaysworking's Avatar
alwaysonDTR
i would wonder where it is, is it in the pump? or on top of the cross member under the engine?
Old May 14, 2009 | 12:24 PM
ofcmarc's Avatar
Look on the rubber skirt between the inner fender and frame.......
Old May 14, 2009 | 09:01 PM
DNRCustoms's Avatar
lol..I looked everywhere 45 min worth yesterday... I sent my Step dad to the pump shop today and they gave him a handfull of them for free!! So, I am back in buisness.. I will probably find it a yr from now tucked away in the corner of my garage!!
Old May 15, 2009 | 02:36 PM
I hope its not in the pump..
hows it run??
Old May 15, 2009 | 08:19 PM
DNRCustoms's Avatar
Its not....I think..lol It runs good, still working out the bugs in the throttle travel, only getting like 3/4 throttle.. Need to bend the pedal arm or something.. But it runs good, so I don't think the spring is in there.. I'm sure it launched somewhere..
Old May 15, 2009 | 08:47 PM
Did you adjust the throttle rod? its left hand thread, be careful.
Did you index the throttle shaft? I'd try moving it a spline before you go bending your pedal arm. that sounds silly
Old May 15, 2009 | 09:05 PM
DNRCustoms's Avatar
Oh...no, I have full pump travel and all that is good.. The pedal has about an inch of slop before it pulls on the cable.. No worries, easy fix.. When I get back in the shop on Mon I'll get it handled..
Old May 16, 2009 | 09:22 AM
not buggin you, but you moved the throttle rod to the inner hole on the linkage correct?
This is a great litttle ''mod''.
Brandon
wmbthe4
May 24, 2011 08:58 PM
shibbyman22
Sep 12, 2010 09:32 PM
dodgeram
Apr 14, 2004 09:28 AM
carl20320
Jul 28, 2003 12:21 AM
97CTD
Oct 28, 2002 08:26 AM
