Darn Pyro Quit - already!
Old Jul 25, 2003 | 11:06 PM
carl20320's Avatar
It has been in since Wednesday night. It has already quit working. :'( :'( Time to give ISSPRO a call unless anyone has any ideas. Power is getting to the wiring; the thermocouple is connected. ???<br><br>This is agravating!! &gt; <br><br>Carl
Old Jul 27, 2003 | 08:15 PM
thumbs's Avatar
Re:Darn Pyro Quit - already!
Take your vom and check for continuity to the pyro. See if there is resistance in the sending unit.
Old Jul 27, 2003 | 08:29 PM
Mexstan's Avatar
As thumbs said, but disconnect the pyro first or else you will get a false reading.
Old Jul 28, 2003 | 12:21 AM
carl20320's Avatar
Whoo Hoo!! Found a connector that had cracked and was giving intermitent continuity. replaced and everything works now. ;D ;D ;D<br><br>This was somewhat tough to find as I was checking the wiring at the gauges adn everything started working when I wiggled a connector. Put the mount back together and it quit again. This happened twice so I figured for sure it was the connector. I was about ready to start cutting and soldering.<br><br>The last time it quit, I could not get it working again. Checked continuity and everything was OK. ???<br><br>That was when I checked the pyro lead. sure enough, could not get continuity in one run. Cut the insulation off the ring and the thing was in 3 pieces. Easy fix and all is in order again. <br><br>Time to get those injectors in now!<br>BOMBs away!<br><br>Thanks for everyone's advice!!<br><br>Carl
catnfool
Sep 6, 2011 03:28 PM
Santaclaus
Nov 29, 2008 08:00 AM
dodgeram
Apr 14, 2004 09:28 AM
97CTD
Oct 28, 2002 08:26 AM
DarrellB
Oct 6, 2002 07:31 AM
