ip questions
Old Dec 19, 2008 | 10:14 PM
speed75's Avatar
ip questions
new to forum just purchased 93 w250 cc auto ctd has leak on bottum of ip wondering if pretty staight forward for reseal from sticky or is worth paying the 600plus for shop to do
Old Dec 19, 2008 | 10:55 PM
peobryant's Avatar
You can almost get a brand new pump for $600, so I would not take it to the shop.
Old Dec 20, 2008 | 06:04 PM
speed75's Avatar
looked on ebay two companys rebuilding pumps any good?
Old Dec 20, 2008 | 06:12 PM
nosler45's Avatar
Look here, lots of good info!
https://www.dieseltruckresource.com/...d.php?t=102027
Old Dec 20, 2008 | 06:17 PM
speed75's Avatar
just dont want to go to over my head
Old Dec 20, 2008 | 07:12 PM
If it's from the timing piston cover, it's very easy once the pump is out of the truck. Two screws, nothing will fly apart. That will usually drip from about the middle of the bottom of the case. If the leak seems to be from between the case and distributor head, you may want professional help.
Old Dec 20, 2008 | 08:23 PM
speed75's Avatar
leaking out weep hole on bottm of pump allso want to do 366 spring and fuel pin is that safe to run without gauges
Old Dec 21, 2008 | 09:33 AM
1stGen545's Avatar
read this all the work on these is easy. I just realised I still have a little work to do on this thread, got side tracked
https://www.dieseltruckresource.com/...d.php?t=200901
Old Dec 21, 2008 | 11:50 AM
speed75's Avatar
that is a very good wright up thanks for all the work
Old Dec 21, 2008 | 12:42 PM
If it's just a play truck it'll be OK. Don't hook a trailer to it with that setup until you get a pyrometer on there.
Old Dec 21, 2008 | 09:41 PM
speed75's Avatar
well i pull a 4500# trailor for work
Old Dec 22, 2008 | 05:50 PM
Leave the fuel pin until you get gauges then. The spring won't hurt anything.
Old Dec 22, 2008 | 07:27 PM
speed75's Avatar
thanks when i pull it apart i will allso do the kdp
Turbocrazy
Feb 25, 2013 04:40 PM
popeye4wheeler
Jan 30, 2011 06:24 PM
Clucker
22
Sep 24, 2009 09:34 PM
GR40RCapri
Oct 30, 2007 09:37 AM
gman07
Apr 15, 2006 08:32 PM
