Intercooling question
Old Jan 19, 2007 | 01:45 PM
efbeason's Avatar
Could I take a stock intercooler off a 91.5-93 model truck and make it fit my 89 non-intercooled? If so would it make a noticeable difference in power, mileage, etc? Thanks!
Old Jan 19, 2007 | 05:39 PM
farmer0_1's Avatar
i want to here this one too. good question. i am looking for a donor cummins and wanted to know if an 89 would be the same if i added an intercooler as a 93?
Old Jan 19, 2007 | 06:25 PM
90firstgen's Avatar
Yes the 89 would virtually be the same as a 93 if you intercooled it. Power would be up, and naturally so would fuel mileage because it would take less fuel to make the same power thanks to the cooler intake air charge. I was going to swap a cooler into mine but I'm gonna get an air to water marine cooler instead... as soon as I can find one. I've still got my intercooler setup if anyone's interested
Old Jan 19, 2007 | 06:28 PM
Micaiahfied's Avatar
the answer is yes you can... but since you're going to have to hack the core support anyways i heard your better off to use a powerstroke cooler... someone will post the years or do a search. they are bigger than the stock 1st gen but still fit. you may need to get the newer style grill to make it work.
Old Jan 19, 2007 | 07:03 PM
farmer0_1's Avatar
thanks for the come back. works for me.
Old Jan 22, 2007 | 09:05 AM
efbeason's Avatar
How much of a power and mileage increase would you guys estimate intercooling my '89 would produce? I currently get around 16mpg and my pump has been turned up 20% over stock and timed accordingly to burn the excess fuel. Thanks!
Old Jan 22, 2007 | 04:56 PM
I wouldn't expect any mileage increase at all. This time of year it might even drop.
Tough to say on the power angle, it doesn't sound like yours is cranked up much. You might pick up 10 hp.
Old Jan 22, 2007 | 06:35 PM
79warlock's Avatar
Do you tow, and what are your EGT's at?
Old Jan 23, 2007 | 08:49 AM
efbeason's Avatar
I do tow some. I do not have a set of gauges right now so I don't know any numbers on my truck. Anyone know where to to buy a good set of gauges cheap? Thanks!
EdmontonCanada
Sep 17, 2013 03:10 PM
bigwhitediesel
Sep 12, 2007 11:53 AM
efbeason
Apr 4, 2007 05:46 PM
Jim Fulmer
Jan 5, 2003 12:39 PM
