hydro boost or vac boost
Old Jul 4, 2007 | 02:35 PM
Onemoparnut's Avatar
My truck now has vac boost brakes but the booster is bad is it worth trying to change over to hydro boost brakes? or should I just replace what I have now?
Old Jul 4, 2007 | 02:36 PM
edwinsmith's Avatar
I'm sure it's much more easy to replace the vacuum boost.
Old Jul 4, 2007 | 03:11 PM
Replacing the vacuum booster involves 6 nuts. Hydroboost conversion is a little more expensive and involves some light fabrication.
Old Jul 4, 2007 | 04:10 PM
Cowboy_Customs's Avatar
If you have the time, money and ambition go hydroboost! Hydroboost rocks, I have had several old Chevy's with hydroboost, every truck should have come equipped with it. Some very light fabrication, a few bucks into the equipment, and a few hours time you'll have a nice setup. Go for it!
Old Jul 4, 2007 | 08:58 PM
DeanM's Avatar
I also vote Hydro. I love it. I put a Ford unit in mine cause I didn't know Dodge made a hydro unit.. duh
So it was a fair amount of work but well worth it.
Dean
Old Jul 4, 2007 | 11:18 PM
BearKiller's Avatar
HYDRO-BOOST will stand you on your nose.
Old Jul 6, 2007 | 07:24 PM
kiszka6911's Avatar
I have read many other threads on hydroboost conversion, I picked up a used hydroboost from a 1985 chevy one ton dually mainly for the cores and brackets. I found a 1994 chevy one ton aluminum master cylinder (RPO JB8 10,000 GVW) which has the proper end configuration, disc/drums, and brake ports to mate with the older hydroboost and dodge brake lines. $99 for new, no core at Autozone. The CTD master cylinder will not interface with the chevy hydroboost as the push rod hole is too deep.
PSC and AGR both reccomended their heavy duty pumps, I am also adding a milemarker hydraulic winch.
From what I have been able to research The light fabrication requires you shorten the brake pedal shaft by 3/4" or space out the chevy bracket with some 3/4" spacers. I am going to try this first to keep the hydro unit a bolt in.
Old Jul 6, 2007 | 09:51 PM
Thanks for the input guys
Old Jul 8, 2007 | 08:04 AM
AUGIE DOG's Avatar
Does any one have photo's of their hydroboost install and some details of what needs to be done ???? Also DEAN M HOW DID YOU DO THE PORSCHE PARKING BRAKE SET-UP. My parking brake gave out about a year ago and a pain to replace/repair. I suspect this is common fore these trucks. Thanks Augie Dog !!
Old Jul 9, 2007 | 09:43 PM
DeanM's Avatar
My Dana 80 has disk brakes. I had to widen the Porsche calipers with a spacer. Then I made an adaptor to mount them. Then I plumbed a hyd handpump in the cab to actuate the calipers.
I have some pics on my computer, email me if you want some.
Old Jul 9, 2007 | 10:59 PM
BC847's Avatar
1st Generation Admin
Summit has a bolt-in kit for about $480 that supposedly fits a '90 to '93. Plumbing is NOT included.
http://store.summitracing.com/partde...5&autoview=sku
wantedwolf
Apr 11, 2009 03:14 PM
Hairy1
16
Mar 31, 2007 04:51 PM
wcbcruzer
Feb 24, 2007 08:33 AM
Boner
26
Dec 5, 2004 03:49 PM
ironman
Sep 2, 2004 08:36 PM
