Vac/Boost T-in Location
Old Apr 10, 2009 | 11:07 PM
wantedwolf's Avatar
The VP and FASS are finaly here and are half installed with only minor 'events"
I cannot figure where to 'T' in the Vac/Boost gauge?
it came with 6' of 1/8 clear tubing, a barbed 1/8x1/8x1/4 Tee, and a little rubber adapter for tubing to Tee connection.
Can this gauge be taped into the Intake Horn? My guess is no
this is the gauge
http://www.autometer.com/cat_gaugede...earch&gid=3472
Thanks for everyones help. I can finally see a light at the end of this month long tunnel. I must have set a time record on this one.
Old Apr 10, 2009 | 11:11 PM
wantedwolf's Avatar
Could I do this? Or do I lose the Vac. by not using a T fitting?
http://www.cumminsdatabase.com/read.php?id=83
Old Apr 10, 2009 | 11:30 PM
Philabuster's Avatar
Just follow the directions in the link you provided. Loose the T-fitting and plumb the line from the gauge straight into the adapter fitting. The gauge can also be tapped into the intake horn.
You should see little-if any-vacuum readings on your gauge with a diesel engine.
Old Apr 11, 2009 | 09:21 AM
wantedwolf's Avatar
thank you for the speedy reply , Thats what Ill do
I wont see Vac readings in Daily operation, but If I have a meltdown I might?
Old Apr 11, 2009 | 03:14 PM
Beast2B's Avatar
if you have a meltdown vacuum will be the least of your worries! intake air has no restrictions in a diesel, so there will be negligible vacuum.
Onemoparnut
Jul 9, 2007 10:59 PM
59FORD
Apr 7, 2006 12:28 AM
aaronisbad
Feb 12, 2004 01:28 PM
KATOOM
Dec 12, 2003 01:08 AM
97Dually
Apr 15, 2003 11:16 PM
