Hydro boost brakes
Old Aug 23, 2004 | 11:16 AM
ironman's Avatar
Hydro boost brakes
Anyone rebuild a hydroboost unit. Power steering fluid is leaking from between master cylinder and the hydroboost unit. Should I rebuild it or purchase a rebuilt unit?
How does the hydroboost unit come apart from the master cylinder, do the brake lines have to be disconnected.
Old Aug 23, 2004 | 02:12 PM
infidel's Avatar
Give brake expert Sam Peterson at 360-357-4958 M-F 8-5 Pacific a call
He has rebuild kits for around $50 and will give you the scoop.
Old Aug 23, 2004 | 03:11 PM
RAM2940's Avatar
Theres a thread from about 2 weeks ago that lists dodge rebuild kit part number. I believe the kit was around $60. Cummins also has rebuild kit. The kits are suppose to come with instructions but is a good link to instructions in the thread mentioned. Found the link.
https://www.dieseltruckresource.com/...did=48012there
Old Aug 23, 2004 | 03:29 PM
ironman's Avatar
Hydro boost unit
Hydroboost unit is located behind the master cylinder it is dripping at that connection.
This is not the vacuum pp which is connected to the power steering pp.
The referenced threads apply to the vacuum pp.
Old Aug 23, 2004 | 03:57 PM
RAM2940's Avatar
Sorry got it confused with the vacuum pump. But anyway if that goes bad theres some good info.
Old Aug 23, 2004 | 04:14 PM
Forrest Nearing's Avatar
I bought a rebuild kit, but never used it. it's yours for $20 if you want it.
Forrest
Old Aug 23, 2004 | 08:26 PM
wgingg's Avatar
ive found that hydroboost units rarely go out. if its leaking between the the master and the hydro its usually the master cylinder thats leaking. check this first its a whole lot cheaper
Old Aug 23, 2004 | 08:31 PM
wgingg's Avatar
sorry i just reread your post iron man and saw you said power steering fuid. my bad. just un bolt the master cylinder (helps to remove the lines and get the whole unit out) then the hydro unbolts in the middle. you shoud beable to rebuild it from there.
Old Aug 26, 2004 | 09:20 AM
JFellman's Avatar
My hydrobboost is leaking PS fluid also....what did you find out about repairing it, Ironman?
Old Aug 26, 2004 | 09:47 AM
ironman's Avatar
I talked to Sam Peterson the brake Guru for Dodge trucks and he said it is an involved precise job not for the non professional. Others who have done found they could not get to all the seals in the unit. I decided to buy a rebuild unit and he recommended an ARI rebuild.
Old Aug 26, 2004 | 05:51 PM
JFellman's Avatar
Thanks, not great news...but I trust Sam's recommendations. Let us know a good source for and ARI rebuilt booster.
Old Aug 27, 2004 | 05:24 AM
infidel's Avatar
Napa sells ARI rebuilds.
Dealer locator> http://www.ezinterchange.com/Locator.aspx#locator
Old Sep 2, 2004 | 08:36 PM
ironman's Avatar
Autozone rebuild 55$ rebuilt by ARI, the company recommended by Sam.
amcom6
Jul 16, 2008 09:00 PM
Onemoparnut
Jul 9, 2007 10:59 PM
Hairy1
16
Mar 31, 2007 04:51 PM
wcbcruzer
Feb 24, 2007 08:33 AM
Boner
26
Dec 5, 2004 03:49 PM
