Help me figure out a part #, or name, or ANYTHING
Old Jun 8, 2006 | 07:09 PM
ouchman's Avatar
The other night my brake lights stayed on after I turned off the truck. After a short time of cussing, I discovered that there is a switch that the brake pedal rests on, which turns OFF the brake lights when depressed. The switch had been pushed back far enough that it wasn't engaging. WHAT is the name or number of the part (or clip or nut or whatever) that holds that switch in place? There is something that holds it, isn't there?
Old Jun 8, 2006 | 08:16 PM
Begle1's Avatar
So you're switch is stuck in? I had the same problem, but it was caused by the swtch sliding down to far rather than getting stuck in... I just had to tie-wrap the switch farther up in order to make contact at the right place.
Unfortunately, I can't help you if it is stuck in. Altough I don't see why you'd need the OEM piece; if I recall correctly, any push-pin switch would have been adequate.
Old Jun 8, 2006 | 08:22 PM
I can't find a good pic of that in my FSM. I would go to the dealer, they can pull up an exploded diagram and find the piece for you. Or just go to the junkyard and get it out of another old Dodge.
Old Jun 8, 2006 | 09:47 PM
ouchman's Avatar
To clarify: The button on the switch isn't stuck - the switch itself gets pushed through the bracket and mine has nothing to keep it in place, so it slowly gets pushed out. I just wasn't sure if it was held on by a nut or a clip or what.
Old Jun 8, 2006 | 09:50 PM
Den's Avatar
Den
I had a problem on my original 91 when it was new. There are 2 types of switchws for the stoplamps. One is for cruise equiped vehicles and the other is without cruise.
The brake pedal itself should rest on the mechanical stop, not the switch itself. In my cause it was adjusted with to much of a intial gap and it resulted in the cruise shutting itself when the truck hit a stiff bump.
The switch needs to be set with a small amount of play in the pedal up position to avoid crushing the switch in and not to much that the bumps affect cruise/light operation.
I found the part listed in an online dealer catalog under:
Mechanical Catalog Electrical , Chassis electrical ,Switches ,Stoplamp switch
No part numbers are listed in the catalog, but the price for the OEM switch is around $30 and it's listed as 92-93
I don't want to be blamed for adverstising (even though I have nothing to do with the site) so if your interested in knowing the site send me a private message. I'll send you the link
Den
Old Jun 8, 2006 | 09:58 PM
Begle1's Avatar
Well, in that case I'd recommend JB Weld.
Old Jun 8, 2006 | 10:25 PM
Den's Avatar
Den
My bad for not reading it clearly..I'm a little woosie on Percocets right now
Had sergury on the roof of my mouth again today..joy joy joy
Den
Old Jun 8, 2006 | 10:27 PM
BC847's Avatar
1st Generation Admin
Check this . . . .
As per the FSM under BRAKES, page 5-9
STOP LIGHT SWITCH ADJUSTMENT
The plunger-type stop light switch is attached to the brake pedal bracket. The switch is directly actuated by a tang on the brake pedal. Switch adjustment is as follows:
(1) Push switch is sealed against bracket. Brake pedal will move forward slightly.
(2) Gently pull back on brake pedal as far as it will go.
(3) Switch will ratchet rearward to correct position. Further adjustment is not required.
Seems I recall to move the switch forward you have to press some tangs or something to let it move forward. Then it ratchets as the brake pedal moves it back to the correct position.
Hope this helps.
Old Jun 8, 2006 | 10:44 PM
ouchman's Avatar
Thanks guys!
tim ramit
Nov 19, 2007 07:51 AM
Patrick Campbell
Sep 20, 2007 02:26 AM
CIN'S DODGE
Apr 7, 2007 05:18 PM
Dan Marino
24
May 15, 2006 08:30 PM
shoffs30
Oct 31, 2005 07:17 PM
