Help me figure this 99 out!!!!!!!
Old Nov 16, 2007 | 10:10 PM
tim ramit's Avatar
Unhappy Help me figure this 99 out!!!!!!!
My 99 24 valve will not start in the morning with out a shot of starting fluid (i know not a good idea but i do wait till the grid heater cools down) after it is started it runs fine and starts right up the rest of the day. It is not the grid heater it works fine and it does it at 60 degres. only does it when it sets over nite. any suggestions would be helpfull.
Old Nov 16, 2007 | 10:11 PM
dj_souvlaki's Avatar
try changing the fuel filter and use some type of additive. maybe the fuel is jelling up.
Old Nov 18, 2007 | 06:35 PM
skidoofan's Avatar
fuel
Sounds like a fuel issue. Maybe you have a leak in your fuel system that is allowing air which would cause a no start issue. Just trying to think of things that would happen when setting overnight. The lack of fuel would give the no start issue. Just a thought.
Old Nov 18, 2007 | 06:52 PM
RickCJ's Avatar
NO fuel! try cycling the pump a few times. What is your fuel pressure?
Old Nov 18, 2007 | 07:03 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Your Cummins has Grid Heaters to warm the intake air for cold starts.
If the ether hits those red hot grid heater wires (Imagine spraying ether into your toaster) you could be in for a REAL unhappy time.
It sounds like an air leak is causing you to loose prime.
It could be in the fuel return line....that's not all that uncommon.
Old Nov 18, 2007 | 07:53 PM
tim ramit's Avatar
Thanks all of you , I am going to get a FASS system this coming weekend, that should take care of it if it is sucking air. BY THE WAY I KNOW ALL ABOUT THE GRID HEATER, AND EITHER AND DONT TELL ANYONE TO TRY IT!!!! (i used it however i waited for 10 minutes after the grid heater cyceld) THANKS for the imput
Old Nov 18, 2007 | 07:56 PM
Shovelhead's Avatar
If the air leak is on the return side (at the back of the head is a common spot), the FASS won't solve the problem.
Old Nov 19, 2007 | 07:51 AM
high bid's Avatar
Did you recently install the fuel press? I have a similiar issue where I think the fp line is allowing the system and filter canister to loose press overnight or after not driving it for the weekend. May want to check that line for leaks. I've also noticed when trying to cycle the lpump to build press that sometimes it won't come on at all.
Patrick Campbell
Sep 20, 2007 02:26 AM
CIN'S DODGE
Apr 7, 2007 05:18 PM
ouchman
Jun 8, 2006 10:44 PM
Dan Marino
24
May 15, 2006 08:30 PM
shoffs30
Oct 31, 2005 07:17 PM
