hc1 turbo size?
Old Apr 26, 2007 | 01:53 PM
Short Box's Avatar
hc1 turbo size?
I bought a used truck and I have read about all these turbo mods and was wondering how do I tell what size my turbo is. The number on it does't match the factory numbers and I was told when I bought it that it had a banks kit on it. The number on the turbo is 3531456. It does have a banks exhaust temp gauge and had a banks muffler(which is now deleted) so it had some sort of kit put on. Any help on this would be appreciated.
Old Apr 26, 2007 | 01:57 PM
Underpsi's Avatar
Banks kits don't change anything to do with the compressor mostly just a waste gate or exh housing
Old Apr 26, 2007 | 02:19 PM
90firstgen's Avatar
Your compressor side should be stock. 54mm
Old Apr 27, 2007 | 02:05 PM
Cowboy_Customs's Avatar
Does the tag on the compressor read H1C or WH1C anywhere? its a stamped in number. Pictures would help out lots, get a few real good closeups.
Old Apr 27, 2007 | 08:22 PM
Short Box's Avatar
The tag reads,
ASSY 3531456
SERIAL C 0152085
3531504-0-6/2
TYPE H1C
I will get some pics as soon as possible. thx
Old Apr 27, 2007 | 08:33 PM
gman07's Avatar
The compressor side is stock then. Is there a wastegate actuator sticking out toward the passenger fender? If so, it's either a 12cm or 14cm wastegated housing (the 14cm was in some banks kits). If not, it's likely the stock 21cm or 18.5cm.
Old Apr 27, 2007 | 09:03 PM
Short Box's Avatar
Question
There is no wastgate. Did they ever change it to a 16? How can I tell what housing it is, can I measure it??????
Old Apr 27, 2007 | 09:24 PM
gman07's Avatar
Measuring really isn't effective, as the measurement is the cross sectional area of the scrolls at some point. It should be stamped inside the exhaust housing, but getting to it will require taking the turbo off.
If it's the stock 18.5 or 21, it should be stamped on the back of the housing (firewall side) near where it bolts to the manifold.
Old Apr 28, 2007 | 08:19 AM
Short Box's Avatar
thanks I will check today
iamallcanadian
Mar 17, 2009 09:15 PM
wollfgang
Apr 8, 2008 03:21 PM
Conn
Jan 10, 2008 05:19 PM
MikeThomas
Nov 10, 2007 10:29 AM
mhuppertz
Jan 25, 2006 07:08 AM
