HC1 flange
Old Jan 23, 2006 | 11:36 PM
mhuppertz's Avatar
HC1 flange
Sorry to , but I am tired of reading through the searches. Someone once on this board turned me on to a web site that sold HC1 flanges for building larger downpipes, and they were cheap. Does this ring a bell?
Thanks!
Mark
Old Jan 24, 2006 | 04:54 AM
bgilbert's Avatar
H1C as in stock ? I believe its something like www.airflo-online.com. Not cheap though.
Old Jan 24, 2006 | 07:06 AM
mhuppertz's Avatar
I have a 16cm housing, and a very nice mandrel tight radius 4" pipe for a down tube. I just need the flange so I can weld 'er up.
p.s. bgilbert, have you dynoe'd your truck? Looks like you have a maxed out 1st gen and I was curious how fast your truck is.
Old Jan 24, 2006 | 01:11 PM
mhuppertz's Avatar
I did find the old links on flanges, but they all seem to be dead links.
Any help here?
Old Jan 24, 2006 | 01:24 PM
mhuppertz's Avatar
I'm stressed out to the max, and need stacks!
If I can score a flange I may do a single 4" stack with a gentle turnout.
Old Jan 24, 2006 | 01:45 PM
G1625S's Avatar
Could you cut the flange off your existing downpipe and weld it to a 3''-4'' adapter, the weld the whole mess to your short radius elbow? That's how I plann to do my own downpipe, when the time comes. Maybe I'm missing what you're getting at, though.
Old Jan 24, 2006 | 01:52 PM
mhuppertz's Avatar
I wanted to build a new downpipe with a new flange because mine has 300k miles on it (and I would rather have the old one in tact in case my rusty welding skills blows too many holes in the new parts!
Old Jan 24, 2006 | 01:58 PM
G1625S's Avatar
Gotcha. I'm trying to learn on my new-to-me MIG...made lotsa holes in stuff myself. Try this:
http://store.airflo.com/exhaust-flanges.html
There's an adapter section, too
Old Jan 24, 2006 | 02:00 PM
bgilbert's Avatar
Ok here ya go: http://store.airflo.com/ad311.html. If that doesn't work, search their site or google for 6BT flange.
Old Jan 24, 2006 | 04:38 PM
spunbearing's Avatar
Rip rook has the flanges also and I believe at a better price. Don't know how to contact them though. Someone will probably chime in.
Old Jan 24, 2006 | 04:48 PM
TLRMAN's Avatar
www.stansheaders.com Call him he has them...
Old Jan 25, 2006 | 02:21 AM
bgilbert's Avatar
No dyno yet. I should have a number by spring time. Big pump, sticks, turbo =?? Fast?? Not this slow shifting 5 speed. I'm sure the clutch and trans would be layed out about mid track if I ran it down the strip ...
TRLMAN, you need to correct your sig, you have a W350 not a D350 model. C'mon now, you're a long timer, you should know W= 4wd, D= 2wd.
Old Jan 25, 2006 | 07:08 AM
mhuppertz's Avatar
[QUOTE=bgilbert]No dyno yet. I should have a number by spring time. Big pump, sticks, turbo =?? Fast?? Not this slow shifting 5 speed. I'm sure the clutch and trans would be layed out about mid track if I ran it down the strip ...
My 5 speed shifts really fast , but I need a bulletproof clutch. If I get a clutch that will clamp her down something else will give, maybe the transfer case. I have repaired/replaced the trans and rear diff, so hopefully those are solid enough. I guess it's a good thing that I haven't been able to afford the clutch! My current clutch (LUK) is like a tranny nanny .....
jklidy
Mar 11, 2010 08:52 AM
iamallcanadian
Mar 17, 2009 09:15 PM
wollfgang
Apr 8, 2008 03:21 PM
MikeThomas
Nov 10, 2007 10:29 AM
Short Box
Apr 28, 2007 08:19 AM
