hx35 vs moded hc1
won't notice a difference.
put the gds 60mm kit on the hx35 and put it on so you get the nice hx35 whistle
Can you fill out your sig? info on truck and stuff so we can help. thanks
OK, I know that this has been beat to death, and I don't want to steal Iam's thread, but anyways:
What would be the next turbo step up after the HC1 + 60mm comp wheel or HX35?
Thanks,
JP.
P.S.:
Iam:
If you just upgrade your compressor you can leave the existing 3" exhaust as it is. Which exhaust housing do you currently have?
JP.
Thanks,
JP.
P.S.:
Iam:
JP.
well igot 4" turbo back and i cant really cut any of that out so i kinda wanna stick to the origal size exhaust housing... would a hx35 moded with 58mm wheel be much better? both with 16cm housings that is
Better than the upgraded H1C? There isn't enough difference to matter. If you can find an HX35 for cheaper than the GDS comp. whell upgrade, then run it. If you can't find a cheap HX35, go with the GDS upgrade.
MikeThomas
Nov 10, 2007 10:29 AM
acook
34
Feb 9, 2007 12:09 PM
Mopar72
Mar 20, 2006 08:14 PM
