Sponsored by:
Sponsored by: CARiD
Turbo addition to a non-turbo tractor...What size?
Old Jan 10, 2008 | 01:06 PM
Conn's Avatar
I've got a small kubota diesel I'd kill to get a turbo on. Stats are:
-14HP stock
-675 cc displacement
-Bore is 2 1/2" (64 mm)
-Stroke is 2 3/4" (70 mm)
-22:1 Compression ratio
-3 cylinder.
Manufacturing of the flanges and fabrication to physically get one on it is no problem, but i'm concerned with the size of turbo I need to consider.
How does one go about determining what size turbo to go with? I'd like to achieve probably no more than 10PSI of boost, just due to the fact that I don't know whether the head will stay on it or not.
Old Jan 10, 2008 | 01:31 PM
Cruizer's Avatar
sounds interesting. I have a 28hp non turbo model and have always though the same.
Old Jan 10, 2008 | 01:56 PM
Conn's Avatar
Yamaha made the Seca motorcycle in the 80s that was 650cc and turbocharged. The displacement is pretty close as far as the engines are concerned.
Don't know if it work or not.
Old Jan 10, 2008 | 02:07 PM
rich's Avatar
if that motor has a lot of hours on it you will kill it from what i've been told as far as putting a turbo on a truck with a lot of miles i would think it would be the same idea
Old Jan 10, 2008 | 03:06 PM
Conn's Avatar
i just had the head off and went through the top end. there wasn't a ridge in the cylinder walls to speak of. The engine looks good. I doubt it has 700 hours on it.
Old Jan 10, 2008 | 03:39 PM
96_12V's Avatar
-14HP stock
That better be one small turbo...pretty uncommon for anything under 40 bhp, as it simply costs too much.
Old Jan 10, 2008 | 04:39 PM
xtoyz17's Avatar
t-25 from a DSM? They spool lightning fast on a 8.5:1 2liter.
Old Jan 10, 2008 | 05:19 PM
patdaly's Avatar
I would be more concerned about short block failure or a fueling failure from either fueling too hard in the NA range or not enough in the boosted range, though that would be less likely than fueling too hard in the NA range.
Many turbo variants of a NA engine use heavier components.
ckt_santiago
Dec 26, 2018 03:55 PM
drewblood
17
Feb 5, 2008 04:19 PM
DieselSmith
Jan 11, 2007 09:17 PM
rharveysr
Jul 18, 2003 01:05 PM
