fuel problems??
Old Aug 29, 2009 | 01:59 PM
DU.DP.'s Avatar
fuel problems??
i started my truck this morning and had it in nuetral. i gave it a good rev just for fun and it stuttered a little bit. i changed my fuel filter and let it run for 30 seconds. gave it some throttle and it didnt do it nearly as bad, should i see how things turn out or keep looking. i am currently going to college, i have tools being in a tech program but am far far from home so i dont have a whole lot of time to work on my truck. any help is greatly appreciated. thanks and i'll keep posting updates on whats going
Old Aug 29, 2009 | 06:45 PM
DU.DP.'s Avatar
im pretty sure that was the problem. i had to go into town a while ago and no problems, but now my water in fuel light is staying on. what should i check for? am i going to have to remove the censor from the bottom of the filter and check things out?
thanks
David
Old Aug 29, 2009 | 07:00 PM
jimbo486's Avatar
check for water in the fuel pull up on the valve at the bottom for a second and see if any water comes out. if none, i would then check that the contacts in the plug are dry.
Edit: btw, did you get the dash insert i shipped you? never checked on the tracking number
Old Aug 29, 2009 | 07:25 PM
DU.DP.'s Avatar
yep i got it. put it in also. im pretty sure theres no water. i'll let it sit overnight and let it all settle just to make sure
Old Aug 29, 2009 | 07:27 PM
jimbo486's Avatar
off topic, but did you paint it like you were planning on doing?
Old Aug 29, 2009 | 08:35 PM
DU.DP.'s Avatar
i went out and checked the bottom drain and no water came out. i held a paper towel under it but it was all diesel, im guessing it could just be the wires. but the seals are all good and no moisture is in them
Old Aug 29, 2009 | 08:38 PM
jimbo486's Avatar
hmmm, maybe take the sensor out of the filter. could be a small shaving or piece of metal (somehow) in there closing the circuit between the contacts. i can't think of any other reason why the light would come on.
Old Aug 30, 2009 | 07:40 AM
Two things:
First, it sounds like you had some air in the fuel system. Changing the filter and priming the system got the air out temporarily, but the trouble will return until you find the leak and fix it.
Second, it's not uncommon for the WIF sensor probes to wind up shorted out on the spring inside the filter.
Old Aug 30, 2009 | 11:17 AM
DU.DP.'s Avatar
ya i was also thinking air in the system. that was my first thought, but i figured start small instead of going all out. im thinking it could be a return line i guaruntee they have never been replaced.
thanks for all the help
Old Aug 30, 2009 | 11:25 AM
ZSkibo's Avatar
You most likely have your WIF sensor threaded too far into the filter which shorts out the sensor on the plate inside the filter. They don't need to be in there super tight.
DJ Turbo.
Oct 13, 2011 09:11 PM
spooling
Apr 3, 2008 09:27 PM
staken
Mar 5, 2008 07:41 PM
95 Dodge
Jul 2, 2006 03:28 PM
simmcows
Nov 18, 2002 10:58 AM
