gauge problems and other problems
Old Mar 4, 2008 | 08:59 PM
staken's Avatar
Having problems with my gauges, spedometer doesn't work, while idling it bounces around. Oil pressure gauge jumps back and forth slowly. Engine temperature bounces back and forth the same way. Also having problems when shifting into third, it grinds shifting down and then up. Also the starter doesn't like to turn, sometimes it takes serveral tries before it turns over, it just clicks. Sometimes I have to use a screwdriver to jump the connections. Anyone who has advice on this, would be greatly appriciated.
Thanks, Staken
Old Mar 4, 2008 | 10:56 PM
Free89W350's Avatar
Check ALL of the grounds very good for looseness or corrosion, that is going to be the best and easiest place to start and I believe that you will find a bad ground somewhere.
Old Mar 5, 2008 | 12:50 AM
pulltilbroke's Avatar
Best Paint (Getrag category)
Yep, sounds like a ground problem to me too
Old Mar 5, 2008 | 07:41 PM
staken's Avatar
thanks id relley never thought of that ill chek them
skywyler
Sep 7, 2006 12:19 PM
Warlord
Jun 15, 2006 07:21 PM
94vortech
May 20, 2006 11:30 PM
1qckdodge
Jul 17, 2005 12:34 AM
Zino
Dec 16, 2003 05:19 PM
