fuel problems
Old Nov 17, 2002 | 05:39 PM
simmcows's Avatar
fuel problems
I have a 1997 dodge.Often after shutting the truck off it will not start. If I crack the injectors and bleed it it will start. Is there a backflow preventer . The truck runs perfect other than this.
Old Nov 17, 2002 | 06:32 PM
1ST GEN.'s Avatar
Re:fuel problems
IT SOUNDS LIKE YOU COULD BE GETTING AIR IN YOUR LINES CHECKALL OF THE FUEL LINES FOR DAMAGE AND SEE IF THEY ARE TIGHT
Old Nov 17, 2002 | 07:36 PM
Monty's Avatar
Re:fuel problems
1st Gen is right. Be sure to pay close attention to the return line off of your pump. They are a known culprit for getting hair line cracks and getting brittle.
Old Nov 17, 2002 | 09:56 PM
Haulin_in_Dixie's Avatar
Re:fuel problems
And remember that air will enter a line through a crack that is too small for fuel to leak out of.
Old Nov 18, 2002 | 10:58 AM
Smokee's Avatar
Re:fuel problems
[quote author=Haulin in Dixie link=board=16;threadid=7165;start=0#68462 date=1037591800]<br>And remember that air will enter a line through a crack that is too small for fuel to leak out of.<br>[/quote] HID is very correct (redundant). Run your fingers along the rubber lines hidden behind the lift pump. Perhaps there will be some dampness.<br>Also, sometimes you cna see a bit of moisture on the starter.<br>george
DJ Turbo.
Oct 13, 2011 09:11 PM
spooling
Apr 3, 2008 09:27 PM
staken
Mar 5, 2008 07:41 PM
95 Dodge
Jul 2, 2006 03:28 PM
Timinva
Dec 16, 2002 05:05 AM
