Fuel Pin
Fuel Pin
I recieved my DennyT Stage II fuel pin last week, and it looks fantastic. I have never installed a pin before, so if anyone could give me step by step instructions, (pics would help ) on how to do the install I would greatly appreciate it.
Thanks,
Parker
Thanks,
Parker
When I put mine in I did it outside in the driveway. It is pretty steep and the front of the truck was pointing uphill. When I finished it would not start. I checked everything and I had installed it correctly. I finally let it back out of my driveway and pointed it down the street. Started up after a couple of cranks. Was a big improvement. With my mods (which aren't mush) I still get about 22-23 mpg.
This weekend I will be changing the antilock valve in the back and figuring why my Isspro pyro gauge just decided not to work. After that why it pulls left even though it has new tires, aligned and all new front brake components. It's fun to work on though.
TIA!
Stinker
Last edited by stinkindiesel; 12-02-2008 at 07:26 PM. Reason: bolded the wrong stuff
I have a very unusual 1st gen. It has always had a very firm brake pedal. Brakes work great but my rears just lock when I do a panic type stop. I have checked the box behind the glove box and removed and reconnected the plug. I did a comlete bleed job of the rear system including the antilock valve. I can only surmise at this point that the valve is not functioning. I do not have either a brake or ABS light. The truck sat for a couple of years and I think the valve may be stuck. I'll report back when it is installed. The valve is not cheap, but I got it for the best price at NAPA for $141. I really do not want the valve disabled as I usually have no load.
I really like my truck but would like to catch up with all the little things some day. Both of my cowl's are cracked by the windshield post but you can no longer get the kits to repair. I also have a leak that makes the carpet wet under the drivers floor side only.
Stinker- I think he means bypassing the valve altogether.
I, too, have an unusual 1stGen. I installed a new master cylinder recently, and even with the RWAL valve still in the hydraulic circuit, I have a great pedal- comparable to the 04 Dakota (except when i make a panic stop, my truck stops instead of letting go the brakes). If you have a good pedal, I'd leave well enough alone, might try backing off the adjustment of your rears just a tad if lock-up concerns you.
Milt- double and triple check all your connections, esp grounds, associated with the pyro hook up. I had a similar problem in a 91 I had.
This post had absolutely nothing to do with fuel pins. Uh..... I saved my money and just ground mine on a belt sander, then buffed it to a highly polished shine.
gaberichison
12-21-2014 12:21 PM
Cowboy_Customs
10-18-2011 01:46 AM
