fuel gauge
Old Nov 1, 2008 | 03:26 AM
HARDTIMES's Avatar
fuel gauge
for those of you running a fuel psi gauge in the cab are you using a fuel gauge isolator??? i was just thinking about if the line cracked or the gauge started to leak that would suck
Old Nov 1, 2008 | 10:09 AM
No isolator on mine. On any mechanical pressure gauge you should put a valve on the engine so you can shut off the gauge in the event of a problem with the line or the gauge.
Old Nov 1, 2008 | 11:42 AM
1985cucv's Avatar
where do you hook the gauge up to?
Old Nov 1, 2008 | 11:46 AM
Most guys install a tapped banjo bolt in place of the factory banjo bolt after the fuel filter.
Old Nov 1, 2008 | 03:47 PM
HARDTIMES's Avatar
where do you get one of these valves?
Old Nov 1, 2008 | 04:55 PM
The hardware store.
Old Nov 1, 2008 | 08:37 PM
mhuppertz's Avatar
It's a very bad idea to plumb diesel fuel into your cab. It's illegal in all racing sanctioning bodies, and good tech guys will kick you off the track for it. Being stuck in a rollover and getting covered in fuel is not my kind of party!
Old Nov 2, 2008 | 12:18 PM
HARDTIMES's Avatar
does anyone have a pic of this? would be very helpfull
Old Nov 2, 2008 | 12:28 PM
Mattster's Avatar
Especially if a fire started.
Old Nov 3, 2008 | 10:43 AM
Caver Dave's Avatar
It's in the stickies (from Bearkiller), but...
While it says for 24Vs, it's the correct part for our 12Vs. Worked perfectly on my truck...
nrussell
Jul 23, 2008 08:58 PM
Igor
Sep 13, 2005 12:47 AM
Greeds22
25
Sep 11, 2005 03:13 PM
engcogod
17
Feb 3, 2005 08:49 PM
Patriot_RAM
Oct 8, 2004 06:10 PM
