Fuel Pressure Gauge & General Gauge Questions
I am hooking up a fuel pressure gauge with no isolator just a needle valve & was wondering if i need to bleed all of the air out of the system, or leave it in there as a damper?
Also how would you hook the gauges up to the factory dimming switch? Is it easy to do?
engcogod,
FYI if you ever have problems with the gauges and they smell diesel from not using an isolator you'll likely have no warranty coverage etc.
Consider getting an isolator, the costs have come way down and it's also protects you from having any diesel fuel smell in the cab. Either way try to bleed off any excess air to get the best results on the gauge. Check our site for prices etc.
Mark @ DPPI
Mark @ DPPI
I second what phox said. No need to bleed!
What you considering is the way to go just make sure you use SS braided line compatable with diesel and you wont have any problems. I pulled the headlight switch and hooked up to the wire comming out of it.
Yep, no need to bleed
I didn't use an isolator or stainless braided line
I did use 300psi rated hydraulic line, and a needle valve though. No sign of leaks, no smell of diesel in the cab, and nice smooth gauge action.
I also hooked up to the headlight switch wire...it made it easier to run the wires having the switch out anyway.
I did use 300psi rated hydraulic line, and a needle valve though. No sign of leaks, no smell of diesel in the cab, and nice smooth gauge action.I also hooked up to the headlight switch wire...it made it easier to run the wires having the switch out anyway.
On my 01 it was a heavy tan wire coming off the headlight switch.
I couldn't find a wire resembling what the instructions described (tan with an orange tracer I believe), and the wiring diagram in Chilton's didn't jive with what I was seeing coming out of the switch either, so I just used the multi-meter to figure out which wire to tap.
If you are hooking up lights to guages get a add-a-circuit from autoparts store. Plugs into the illumination fuse and also works the dimmer function. Alot easier than getting to light switch. With the add-a-circuit the guages have its own fuse and the factory lights use its own fuse.
Originally posted by Tx Firefighter
The guys at ISSPRO told me no isolator required for their guages.
I run mine with a needle valve and hydraulic hose straight to the pillar.
Just got my DI pricol FP gauge. I'm planning on running it without a isolator. Just waiting to get the hose and fittings. Those of you that have used the hydraulic line, what size did you get. And if I splurge for braided stainless, do I get -4 or -3?
