Where to install the trans temp guage
Old Nov 2, 2008 | 08:11 PM
Free89W350's Avatar
Question Where to install the trans temp guage
Well I am getting ready to install the trans. I have to flush out all the lines and then I am ready. I have a rebuilt 518 and a Georend's converter, now that I have all that money tied up in the trans area I am going to install a guage (which I have had for the last year). Where should I install the probe???? I have done some searching and have not found a strait forward answer so I figured I would ask the group. If any has any pics and instructions on where they installed theirs I would greatly appreciate it.
Thanks in advance.
Old Nov 2, 2008 | 09:39 PM
https://www.dieseltruckresource.com/...30#post2265830
look at this ryan, i just brought this old thread back to the forum.
Old Nov 2, 2008 | 09:43 PM
and the lifesaver part for mounting the tranny probe
Adapter - 2271
the adapter allows you to remove the factory sender (leave it plugged in but tied out of place) and put the mech sender in without hindering the flow of the tranny fluid. the factory senders only purpose (that i know of) is to kickdown out of o/d above something crazy like 270 degree. since you will be watching the gauge and not allowing that anyways there is no reason (IMO) that you shouldn't use the port. there is an image pending approval of the adapter in my gallery. all gauge #'s are for autometer Z-series
dug this up too from micaiahfield in a old thread called gauges, gauges,gauges
Old Nov 2, 2008 | 09:45 PM
This is not me talking it "Chass" in the blue font... its this thread i dug up... https://www.dieseltruckresource.com/...ans+temp+probe
"My Autometer tranny temp guage came with an adapter that screwed right in to the stock sensor hole. I didn't have to buy anything else. Part# ATM-3357 from Summitracing.com"
Old Nov 2, 2008 | 11:13 PM
Free89W350's Avatar
Thank you Brandon that helps alot .
Old Nov 2, 2008 | 11:22 PM
Free89W350's Avatar
Does a 3speed non od truck have the temp sensor? I think that will be my problem because I am going from a 727 to a 518.
Old Nov 3, 2008 | 05:56 AM
archer39's Avatar
i have mine installed in the pan without no problems. i drilled and taped a 1/8 npt hole in the pan works perfect
Old Nov 3, 2008 | 06:09 AM
JD730's Avatar
Nope, those 727 trucks don't have the high temperature switch, which is what some people call a temperature sensor.
I have one in the hot line and one in the pan on my truck.
Let me know if you want to put it in the hot line, I can get a JIC to JIC to pipe thread T for you and cut and flare the steel line to put the sender in.
Old Nov 3, 2008 | 10:36 AM
The_Head's Avatar
Since they don't make a triple mount, I had my trans temp gauge mounted on the floor on the "hump" of the floor board. Seems a third gauge would be too high to read anyways.
Autometer sells the simple flat brackets for the 2 & 1/16" gauges for pretty cheap. You can get them in 1, 2, and 3 hole flavors. I was thinking of putting a FP gauge down there in the future.
I hope it is ok if I ask a question on this subject.... my probe is installed in the location provided by the double deep Mag Hytec pan I have on my trans. I think my gauge reads low. When driving around unloaded, It hardly goes above 100* Once in a blue moon it will touch 125*. I thought I read somewhere that normal is 170*...
Old Nov 3, 2008 | 10:55 AM
Caver Dave's Avatar
While not a "bolt-on" triple pillar mount, they ARE made...
I can see the gauge pretty well, even though it's on top
Old Nov 3, 2008 | 10:58 AM
The_Head's Avatar
Yeah... not my style. I would prefer to stay away from pillar mounts altogether myself, but 2 is ok.
Old Nov 3, 2008 | 11:15 AM
Free89W350's Avatar
I think as far as location of the guage I am going to put it where the "Cargo" lamp switch is along with a fuel psi guage. That is until I build my 3 to 4 guage pod where the speaker grill is in the dash. My problem is the probe location which I think I am going to go with what JD730 suggested and ad a "T" into the hot side line.
Lee Jolly
Jun 19, 2006 04:20 PM
Dieseldog800
Feb 17, 2006 05:05 PM
firesine
Nov 24, 2005 10:58 AM
live wire
Jul 21, 2003 07:26 AM
Dodgezilla
Mar 2, 2003 04:10 PM
