front leaf spring bushing
Old May 1, 2018 | 01:44 PM
Brian.B's Avatar
hey guys what size are the main front spring bushings.....my bushing is completely gone
Old May 1, 2018 | 01:48 PM
johnh's Avatar
dealer question
Old May 1, 2018 | 11:52 PM
PapeCAT's Avatar
Any spring shop worth their salt should know the dimensions. Note that around 91.5/92 they switched to larger bushings for the front springs fwd eyelet that took a 5/8" bolt instead of the 1/2" which would oval out the shackle hole.
Old May 3, 2018 | 08:52 AM
sooty's Avatar
there are polyurethane bushing kits that don't require pressing from skyjacker and many other manufacturers
Old May 3, 2018 | 09:05 AM
mknittle's Avatar
As far as I know the spring eyes are all 1" diameter the spronga are 3 1/2 wide and the bolts are either 1/2" or 5/8".
Old May 3, 2018 | 09:17 AM
1st gen spring are 2 1/2 inches wide. 2nd gen leaf springs are 3 inches wide.
Old May 3, 2018 | 11:09 AM
bigragu's Avatar
Geno’s garage carries the bushings for the front, made by energy suspensions.
Old May 3, 2018 | 04:06 PM
mknittle's Avatar
OOPs brain fart.
Old May 6, 2018 | 05:56 AM
Jungle's Avatar
I also have the 1" ones with 5/8" grease bolts here;
Dodge front spring 5/8" grease bolt up grade - Dodge Ram, Ramcharger, Cummins, Jeep, Durango, Power Wagon, Trailduster, all Mopar Truck & SUV Owners. Dodgeram
I also stock the 1 1/4" bushings.
Jim
Old Aug 30, 2023 | 09:38 AM
E.Roy's Avatar
Between 1972-1991.5, all front leaf spring bushings are 1" OD with 1/2" bolt and 2 7/8" wide (2.5" springs)
The very front leaf spring eye only for 1992-1993 jumped up to 1.25" OD with 5/8" bolt (rear eye is still 1" OD with 1/2" bolt)
If you want to fit a 5/8" bolt into a 1" eye, say you're installing Skyjacker springs which have 1" eyes under a 1992-1993 truck,
you do have options: https://archivegarage.com/explore-ar...bushings-1x625
Old Aug 30, 2023 | 01:23 PM
Jungle's Avatar
I have these;
https://www.ramchargercentral.com/th...-grade.134004/
rrfarm
Feb 3, 2012 07:28 PM
Mopar1973
Sep 25, 2011 05:27 AM
MARF75
Jan 26, 2011 03:33 PM
mhuppertz
Mar 7, 2010 09:26 PM
dieselcarpenter
Off Road / 4x4
15
Feb 3, 2008 08:06 PM
