front leaf spring bushing
hey guys what size are the main front spring bushings.....my bushing is completely gone
Originally Posted by brian.b
(Post 3347903)
Any spring shop worth their salt should know the dimensions. Note that around 91.5/92 they switched to larger bushings for the front springs fwd eyelet that took a 5/8" bolt instead of the 1/2" which would oval out the shackle hole.
there are polyurethane bushing kits that don't require pressing from skyjacker and many other manufacturers
As far as I know the spring eyes are all 1" diameter the spronga are 3 1/2 wide and the bolts are either 1/2" or 5/8".
Originally Posted by mknittle
(Post 3347949)
Originally Posted by Brian.B
(Post 3347903)
(Post 3347950)
1st gen spring are 2 1/2 inches wide. 2nd gen leaf springs are 3 inches wide.
I also have the 1" ones with 5/8" grease bolts here;
Dodge front spring 5/8" grease bolt up grade - Dodge Ram, Ramcharger, Cummins, Jeep, Durango, Power Wagon, Trailduster, all Mopar Truck & SUV Owners. Dodgeram I also stock the 1 1/4" bushings. Jim |
Between 1972-1991.5, all front leaf spring bushings are 1" OD with 1/2" bolt and 2 7/8" wide (2.5" springs)
The very front leaf spring eye only for 1992-1993 jumped up to 1.25" OD with 5/8" bolt (rear eye is still 1" OD with 1/2" bolt) If you want to fit a 5/8" bolt into a 1" eye, say you're installing Skyjacker springs which have 1" eyes under a 1992-1993 truck, you do have options: https://archivegarage.com/explore-ar...bushings-1x625 |
Originally Posted by E.Roy
(Post 3386215)
The very front leaf spring eye only for 1992-1993 jumped up to 1.25" OD with 5/8" bolt (rear eye is still 1" OD with 1/2" bolt) If you want to fit a 5/8" bolt into a 1" eye, say you're installing Skyjacker springs which have 1" eyes under a 1992-1993 truck, you do have options: https://archivegarage.com/explore-ar...bushings-1x625 I have these; https://www.ramchargercentral.com/th...-grade.134004/ |
