Engine chuggin at idle in gear.
This problem has been with me for a long time( since I have had the truck but has gotten worse) and now that the trans is tightened up its a little more noticeable.
I checked crank end play when the flex plate was off and there was no movement.
There are 2 problems 1 is chugging in gear at a idle. The engine is surging if that's a better term. Rpm is not to low, if anything its a little to high to try a compesate. Also I'm getting a resonance that is vibrating every thing in the truck, panels , seat belts you name it. Right as im coming up to a stop its rattling everything. Its not a engine miss.
This problem has been there before the injection pump rebuild and the trans rebuild. It was there when I got the truck but has gotten worse, a lot worse also with the 4" exhaust but I garrente its not touching anything. Ive check body mounts and can't find anything touching but thats kind of the resonance that I feel as if the body touches the frame of engine some were. It still seem to eccesive regardless if something is touching and I think the chugging or surging and vibration are related.
Could worn out injectors do this? Or maybe this is timing related. Im going to back off the timing an 1/8 tomorrow at work to see what happens. The vibration seems like uneven cyl balance but it does not feel any different per cyl. What I mean is that it feel like a cyls do it the same. Thats why I think the timing might be to far advanced. Maybe its the opposite and I need to advance it, I really am at a loss.
Any and all help would be great
Thanks
Yuri
Thanks
Yuri
Hey tron, My truck got alot worse with the 4" exhaust. I have the same vibration when i come to a stop also. I am going this morning to put a donaldson mo85171 muffler on it. I will report back. It seems the 4' resonates alot more under the truck. I did not have the problem with only the 4'' from the t-case back,once i went full 4'' it got bad.
I have cracked all the lines and it seems to make it run worse evenly over all cyl's. If there is air coming in some were I can't find it. I have pressurized the tank for to hours and found no leaks. Thanks Wanna
So I backed the timing off an 1/8 and ended up with a miss fire on 1 cyl, consitantly 1 cyl, not a random miss....so that did not work. So I advanced it an 1/8 past were it started from and no miss but very rattly so I set it back to were it was. No idea still.
The one cyl miss seems odd when the timing was retarded an 1/8.
Tron, I got the new motor mounts in and the vibration in the cab has gone down some, but is still there. I guess the only thing left is cab mounts. I think it has something to do with the 4" exhaust because when i had 3" off the down pipe and thru the t-case then to 4" i did not have this vibration. Hope this helps, i am with you man. It gets annoying. Justin
wadecool
Nov 13, 2006 12:37 AM
JohnInNH
15
Sep 3, 2006 08:22 AM
trout74
Aug 29, 2005 06:25 PM
Hummin Cummins
Dec 25, 2002 12:29 AM
