Different kind of runaway
I was tooling down the freeway this morning and when I let off the foot feed the the engine didn't get the message. I tromped it to see if it was just stuck and it stuck floored.
About this time I was realizing the error of my ways in not having a shutdown solenoid or a pull cable!
I had to get it pulled over in 5th with both feet on the bonders to kill it!
Looked under the hood and found a frayed throttle cable. Nursed it to Napa, and they said the closest cable was in New Jersey and a week away, so I bought a stiffer spring until I find a new cable.
Any ideas where I can get one that is not the dealership?
-mark
-mark
I had something similar like that happen to me in a 340 4sp cuda going down the interstate in Ft.Worth. throttle stuck and as I was nearing the wrong end of an 18 wheeler, I pushed in the clutch ( tachin about 7K), figured it was gonna blow anyway and if it did, it was going to do it MY way.....Smashed on the throttle and it came undone. One of the few times in my life I went home and checked the shorts !
Actually making one isn't that hard. I've made quite a few cables. The stops are aluminum and you could easily crush them onto either end with a small c-clamp. I made a short length 1/8" cable as a bandaid for one of my parking brake cables over a year ago and it's still work just fine.
The skinny shift cables from a ten-speed bicycle might pull through the casing; then the ends could be fabbed from 80-pound class crimp-on wire leader collars from your local sporting goods store. That's how I used to fix my broken shift cables.
Received 1,637 Likes
Mark
This guy says it's available @ Carquest Granted the thread is a few years old, but you might just get lucky.
http://www.cumminsforum.com/forum/91...tle-cable.html
I don't know.
Where in NJ is it @ ? If it's local, I'll pick it up for you and overnight it, if you want me to.
BTW,
It's available on EBAY
http://compare.ebay.com/like/1304652...=263602_304662
Here it is available even cheaper
http://cgi.ebay.com/ebaymotors/Throt...item45f8c622a5
T.
I don't know.
BTW,
T.
how do you shut it off if you have no shut off solenoid or pull cable? Good thing you have a manual. Thats where my auto scares me, i can't just dump in it 5th if nothin else works.
Hintz
16
04-24-2009 06:19 PM
jamesbfishin
03-01-2008 01:57 PM
Fummins
05-05-2005 11:43 AM
Fummins
05-05-2005 03:14 AM
