Cruise set button makes truck go faster!!!
Anyone have an idea why this is happening??
Was cruising along today pulling a hill and noticed I was just flying by everyone else.
Had that "Man I love my truck moment" when I realized I was 35kmh over the limit
Fiddled with it the rest of the way home but kept doing it.
Soon as I hit "set" she just keeps climbing up the speedo.
mine does this after I got new switches. as soon as I press on and set it goes to full throttle. I adjusted my Potentiometer many times and it didn't change. I've heard it could be the servo but never have checked it or got a new one yet to be sure. It may be your problem though.
Yep, it's an undocumented feature.
ARM
Automatic Race Mode
Seriously, I suspect the PCM is expecting the TPS to swing (throttle movement), and if it's fixed, ie a potentiometer, it overcompensates a bit. On a stock motor it's not really an issue, but if you have things turned up so throttle response is snappy, it could get goofy.
With a little vacuum flow restriction taming down the throttle response when in cruise, it should settle down to reasonably normal.
ARM
Automatic Race Mode
Tedonlin150
Feb 4, 2010 11:37 AM
can17
Nov 10, 2008 02:53 PM
1969mach1
Apr 27, 2007 10:43 PM
TurboTed
May 12, 2004 04:51 PM
