O/D button Vs. Tow/Haul button
Old Feb 3, 2010 | 12:12 PM
Tedonlin150's Avatar
Just curious what the difference is.
Old Feb 3, 2010 | 12:24 PM
055055.9's Avatar
O/D just locks out overdrive. Tow/Haul changes transmission shift points.
Old Feb 3, 2010 | 12:56 PM
troll3193's Avatar
depends on the year too..
in 04.5 tow haul, only had a tow/haul switch and it extended the shift points and prevented OD.. I had one of these trucks and would use tow/haul up to about 55mph, then turn it off, so I could get into OD.
In 05, it is a tow/haul mode, but will go into OD..
In 06, you can turn on tow/haul, that will still enable OD, but if you push the button again, it will lock out OD..
Sorry don't have details for before 04.5 and after 06, but have driven these three years and the behavior is different
Bryan
Old Feb 3, 2010 | 02:45 PM
no_6_oh_no's Avatar
The 03-04 is the same, OD off only with no shift enhancements. The 05 is the first year with a true TH that modifies shift pattern and lockup strategy.
The 06-07 trucks had both. The OD off was just a standard shift\lockup program while the TH had the more aggressive shift\lockup.
Old Feb 3, 2010 | 03:05 PM
pdogg's Avatar
"lockup strategy"... I like it..
but yeah, in '05, the TC locks up in 2,3 and 4
Old Feb 3, 2010 | 03:27 PM
NJMurvin's Avatar
In what gears on an 04.5 does the trans lock up? I know it does in 3rd (in T/H) and OD because I have felt it. Will it lockup in 2nd as well?
Old Feb 3, 2010 | 04:26 PM
no_6_oh_no's Avatar
Not sure whether the 04.5 will lock in auto 2nd, my feeling is it won't but thats a guess. It might in manual 2nd.
My 05 locks in all 4 gears but it has been tweaked a bit.
Old Feb 4, 2010 | 11:37 AM
NJMurvin's Avatar
I thought I read somewhere that it does lock up in 2nd. I only had one occasion towing where I had to use 2nd. I was going up a pretty steep climb on a mountain road with lots of switchbacks. It kept hunting between 2nd and 3rd, so I put it in 2nd and took it easy. I don't recall whether I could feel it lock up or not. Fortunately, it wasn't long climb.
SilverRam3500
Feb 25, 2007 08:24 PM
Hemlockusa
Oct 9, 2005 04:53 AM
eileeneh
Jan 23, 2005 09:21 PM
USMC64-70
Nov 15, 2004 03:34 PM
thejeepdude
Nov 3, 2004 02:57 PM
