crossover steering ???
Old Nov 1, 2007 | 10:24 PM
93firstgen's Avatar
can a crossover setup still use the antisway bar or will it need to be removed?? if it can be used, anyone have one they wanna get rid of?
Old Nov 2, 2007 | 05:52 AM
G1625S's Avatar
Ask these guys--they'll know for sure: www.offroaddesign.com They've done a 'few' d60 crossover setups
Old Nov 2, 2007 | 10:28 AM
leper's Avatar
If you are still using one with 6" of lift, then you have already adressed the mounting location issues. Unless the crossover actually comes in contact with it, you can leave it. However, swaybars really limit flex offroad. I used somw quick disconnects on mine for a while, and eventually removed it all together.
Old Nov 2, 2007 | 11:08 AM
Ace's Avatar
Ace
Running swaybars on an off roader is like ordering a supersize whopper meal and diet coke. Kinda mutually exclusive, concept-wise.
Old Nov 2, 2007 | 05:09 PM
93firstgen's Avatar
i uderstand the whole limiting flex thing, i run a cherokee that is 8 inches over stock. it has diconnects on the antisway though. my truck doesnt have a bar, po took it off when he lifted it.thats why i was aking if anybody had one to get rid of. i like the stability factor on-road and dont mind having to get out and disconnect, already gotta lock it in.
Old Nov 3, 2007 | 09:41 PM
93firstgen's Avatar
soooo, nobody with a lift has a antisway bar anymore?? the truck just feels "loose" to me.
Old Nov 4, 2007 | 02:27 AM
Murphy85's Avatar
When I put on my lift I took off the sway bar. I think it feels loose especially when hitting bumps it seems to wobble side to side. I may try hooking it back up and see what it does.
Old Nov 4, 2007 | 05:13 AM
KRB's Avatar
KRB
They came with swaybars?
Old Nov 4, 2007 | 06:36 AM
Front swaybars were optional on 4x4's, standard on 2wd's.
Old Nov 4, 2007 | 09:55 AM
Ace's Avatar
Ace
"Rear" swaybar fixed that loose feeling for me. Added one to the front as well. Truck turns pretty flat and the back end stays put now, especially with a little weight in the bed. Here's how I adapted a 2nd gen rear bar:
http://stuff.is-a-geek.net/PhotoAlbu...ics/CDT_25.jpg
http://stuff.is-a-geek.net/PhotoAlbu...ics/CDT_26.jpg
http://stuff.is-a-geek.net/PhotoAlbu...ics/CDT_27.jpg
http://stuff.is-a-geek.net/PhotoAlbu...ics/CDT_28.jpg
I don't think crossover steering is going to work with the front bar, tho....
Old Nov 4, 2007 | 10:11 AM
Ed ke6bnl's Avatar
Just picked up a new to me 98 dodge 4x4 it does have a Don Thuren 3rd gen track bar, and carli suspension end links. Not sure if I have the crossover steering. I do have a long bar that goes from the pitman arm on the driver side to the passenger side where i believe it connects to the bar the turns the wheels. is that what we are referring to thanks ED
Old Nov 4, 2007 | 10:45 AM
Ace's Avatar
Ace
That would be crossover steering!
Old Nov 4, 2007 | 11:08 AM
dodgediesel's Avatar
Get rid of it if you are going on some hard core trails!! Crossover steering with a Dana 60 is simple and the only way to wheel!! My 1980 Powerwagon loves it...
bggrndodge
Jul 21, 2006 09:59 AM
vinny
Mar 16, 2006 08:56 PM
smokindog
Jun 5, 2005 11:49 AM
HOHN
May 10, 2005 01:06 PM
ramcummins
Apr 30, 2004 08:15 PM
