Crossover steering..
Old May 9, 2005 | 04:46 PM
HOHN's Avatar
Perusing the ThurenFab site, I see the crossover steering kit.
1) Why would you want crossovr steering?
2) Why is there no steering damper?
3) How do you adjust TOE with the crossover setup?
Justin
Old May 9, 2005 | 05:52 PM
Cowhand's Avatar
Re: Crossover steering..
Justin
1) With the stock "Y" link configuration, when the front suspension compresses it causes the wheels to toe out. In my case, it caused the tires to cup bad. It also eliminates the weak TRE's and replaces them with heims. Two schools of thought on running heims on the street....I like them alot better because after 10K miles there is ZERO play in the rod ends. TRE's never lasted this long before they developed play on my truck. I went through TRE's like socks.
2) Don't really need one...I have no bumpsteer and no vibration or shimmy.
3) Loosen the jam nuts and pop the left side off the knuckle. Give it a turn or two and put it back on. My toe has only been adjusted once (when I put it on) and it's still dead on. First time since I've owned the truck that the tires haven't started to cup. 10K on this set and I haven't rotated them yet, they're wearing even all the way around.
Overall, steering feels alot more precise and solid. Since doing the x-over steering and track bar, I haven't had anything that's felt even remotely close to the death wobble....
Conrad
Old May 9, 2005 | 10:11 PM
HOHN's Avatar
Didn't some Rams have the crossover setup from the factory???
You said HEIMS!!!! I LOOOOOOOOOOOVE HEIMS!!!!!!
Would this help my BJs last a little longer? I think they are gone at 35K
JLH
Old May 10, 2005 | 11:22 AM
walexa's Avatar
How would you know whether you would need the straight or bent?
Waylan
Old May 10, 2005 | 11:49 AM
HOHN's Avatar
I think Thuren could tell you. Looks like bent gives more clearance on certain trucks.
I have to confess, I love the KORE suspension, but it looks like the Thuren setup could let you run those sweet Fox Shox w/o the $$.
jlh
Old May 10, 2005 | 01:06 PM
Cowhand's Avatar
jlh
Tie rod is bent to clear the diff cover, drag link it bent to clear the sway bar mounts. One of the trucks pictured on Don's site is mine.
I'm running the King shocks instead of the Fox.....difference for the 2.5 is close to $100/shock. Don can set them up with the same valving......
I can give you some info on coils if you want it, PM me.
The KORE system is good stuff, but it still relies on the stock steering and track bar.
jslamerman
Jan 3, 2007 08:54 AM
bggrndodge
Jul 21, 2006 09:59 AM
vinny
Mar 16, 2006 08:56 PM
smokindog
Jun 5, 2005 11:49 AM
ramcummins
Apr 30, 2004 08:15 PM
