91.5 with hard brakes when cold???
Old Nov 4, 2007 | 11:05 AM
53 willys's Avatar
Hey guys my dad has a 91.5 cummins and when ever the temps cool off the brakes go hard until the truck runs or drives for a while/warms up.
I am thinking that the vacuum pump is getting lazy but I thought I would ask what you all think it could be???
I have not read the vacuum pump rebuild in the sticky yet but I noticed it said it was for a non intercooled truck... so are they the same as far as rebuild or are they different??
thanks for any tips or info you got
Old Nov 4, 2007 | 11:33 AM
BearKiller's Avatar
A decent dash-mount vacuum-gauge is in-expensive and simple to install, and will pay for itself, over and over, as a constant monitor of vacuum system health and well-being.
Complimented with a decent hand-held portable vacuum-gauge, vacuum problems can be pin-pointed in a process of elimination.
There are three different vacuum-pump designs on 1st Gen. trucks.
The earlier trucks have a twin-pod diaphragm pump that is fairly bullet-proof and, when split into two seperate systems, makes plenty of vacuum for the trucks needs, and also a big vacuum-over-hydraulic trailer brake system.
Later trucks have an entirely different VANE-pump system.
We never had much success getting these to support the needs of a vacuum-brake equipped trailer, necessitating the need of a seperate belt-driven pump for the trailer system.
This goes along with your question and I posted a link to a source for pump parts and kits:
https://www.dieseltruckresource.com/...d.php?t=176088
Some good information on that pump site.
Old Nov 4, 2007 | 11:46 AM
ofcmarc's Avatar
Pop the big plug off the brake booster. Cover the open end of the line with your hand. Runn the truck for a minute or so and shut it off. If the system holds vacuum you probly need a booster. I know I do. Mine leaks but works well untill it gets cold outside then the leak really shows and my brakes get hard.
Old Nov 4, 2007 | 11:54 AM
53 willys's Avatar
Thanks for your help.....I just read that thread right after I posted, I guess I should have checked the threads a little better or searched
Thanks for your help tho
good info thanks
man I also read the hydro boost conversion thread!!! to me that seems like a cheap and easy route to get BOMBER brakes. It's hard to beat hydroboost brakes
Thanks for your help guys
Dargo
Jan 12, 2018 07:45 PM
LUKE-MM-PULLER
Oct 31, 2010 09:35 AM
wildcargo
Nov 29, 2005 04:20 AM
DZLPWR
Apr 17, 2004 09:53 PM
ejb
19
May 19, 2003 01:08 PM
