Crewcab update...
Old May 22, 2016 | 05:48 AM
  #1156
Alec's Avatar
What this did was lower my brake pedal and cause my brake lights to stay on.
And slightly apply your brakes.
When you plumb the system with the steering gear return feeding the branch of the tee, it raises the back pressure on the hydroboost return line, and causes the booster to apply slightly without any pedal input.
I am very surprised that you did not have trouble on your trip with dragging brakes.
Old May 22, 2016 | 11:28 AM
  #1157
Interesting information...Thanks you!
Wouldn't it be the other way around? If the HB return was feeding into the branch of the tee with the steering gear return, then the HB back pressure would be higher? In my mind there would be less back pressure with a straight line shot to the reservoir?
No I had no issues with the brakes at all. Nice and cool...I check tires, lights and hub temps at every stop...I'm a trucker so it's just habit.
Old May 22, 2016 | 01:06 PM
  #1158
Did a 1000+ mile trip to PG and back...pics and story here...
https://www.dieseltruckresource.com/...2/#post3304561
Old Aug 9, 2016 | 07:10 PM
  #1159
Back again...sort of....
Little Update since I have been away from the board for a about a month now.
We made the move to PG and I have been crazy busy getting set-up here on the new property.
I have been using Patches for what it was built for on the property...hauling brush, material and equipment. Thank goodness I did the 4wd conversion since I have had to use it just cruising about the property.
I will be going down to the coast with my daughter soon. She needs to see the orthodontist, and I will be grabbing Snoball to haul it back up.
All pics and stuff on are on the old computer hard drive, so will have to get those moved over to my new Mac.
Will update a bit more when I have time.
Old Aug 9, 2016 | 07:15 PM
  #1160
Blue Goose's Avatar
sounds like fun,,,,not. don't work too hard TC.
Old Aug 9, 2016 | 07:16 PM
  #1161
Thrashing is okay…and just when I was starting to get worried.
I figured you were busy with the new property.
Glad to hear all is good with you.
Old Aug 9, 2016 | 07:38 PM
  #1162
crazy clem's Avatar
Good to hear all is well in PG . Man I wish I could convince the wife to move away from this rat race on the coast .
Old Aug 9, 2016 | 08:53 PM
  #1163
mknittle's Avatar
Great to hear from you Brian, I figured you were pretty busy after the move.
Old Aug 11, 2016 | 10:47 AM
  #1164
Alec's Avatar
I'm glad you are doing well, and enjoying your new place. Moving is not much fun, and as I recall you have had a couple of places to clear out and take care of . . . But it sounds like you are getting over the hump!
Somehow I missed this back in May . . . But the volume of fluid through the PS gear is much greater than that through the booster. If that high flow enters the branch of the tee, it will want to go out each end of the trunk with roughly equal pressure. If it enters the trunk, it will want to go straight through the tee out the other end of the trunk. In some situations, this will even have a small venturi effect and draw slightly on the branch of the tee. . .
Not sure that you care at this point. It seems like your hydroboost is working well, regardless.
Old Aug 25, 2016 | 08:44 AM
  #1165
bannerd's Avatar
Worst thing about moving... you can never find anything and end up buying it again.
Old Aug 25, 2016 | 01:13 PM
  #1166
I have spent hours searching for those things I know I have...but cant find the box they are in!
Old Aug 25, 2016 | 01:35 PM
  #1167
mknittle's Avatar
I get to do that in about a year.
Old Aug 25, 2016 | 06:41 PM
  #1168
Blue Goose's Avatar
buy it again....then it will magically reappear.....
Old Aug 25, 2016 | 06:46 PM
  #1169
mknittle's Avatar
right where you looked at least 100 times! I think this is proof of Murphys existence
Old Aug 25, 2016 | 06:55 PM
  #1170
Blue Goose's Avatar
I have tools that do this too....
